Center Console
Old Jul 17, 2005 | 02:39 PM
Zincpony's Avatar
Zincpony
Default Center Console
how do you take appart the center console on a 01 v6. im going to install my unit and system today and i cant take the center cover out and get in there.
Old Jul 17, 2005 | 06:09 PM
lrall's Avatar
lrall
Default RE: Center Console
your head unit? you shouldnt need to take off the center console for that, just pop out the old and get all the wires connected to your new one....i must be missing something cuz you shouldnt have to take it off for a head unit...
Old Jul 17, 2005 | 06:41 PM
Zincpony's Avatar
Zincpony
what i meant was the cover around the dash in the center where the radio, AC, and that other stuff is
Old Jul 17, 2005 | 09:47 PM
LIVNBIG's Avatar
LIVNBIG
Well..according to brother HAYNES..
Remove the radio and compact disc player.(if equipped)
Detach(fancy for unscrew) the retaining screws from the lower half of the trim panel..mid way up you should see 2 screws, I checked my 00 GT
Using a small screwdriver, pry out the clips securing the top of the bezel then unsnap the clips in the center of the trim panel and remove it from the vehicle
Installation is the reverse from removal
That's what HAYNE'S sez...shoot me a pm if you have any more questions!! Looks pretty straight forward!!
Good luck!!
Old Jul 18, 2005 | 04:27 AM
myfirststang's Avatar
myfirststang
Your deck can slide right out. You just need the Ford Keys to remove the deck. I've also heard that you can use coat hangers to get it out. I think www.mustangworld.com has a tut or a diy on this.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
