Mach 460 questions
Old Feb 2, 2010 | 07:33 AM
smythge's Avatar
smythge
Default Mach 460 questions
I am sure this has been asked before, but I am not finding the answers I am looking for.
I have a 01 with the Mach 460 I am currently running two 10" subs with an external amp everything else is stock. I am going to change the head unit, I have the Metra 70-5519 harness, my questions are:
1. Which channel do I use in the back of the head unit for the 2 RCA jacks off of the Metra 70-5519 harness? Do those RCA jacks just run the two amps in the rears? I want to use the Sub channel on my head unit for my 10" subs not for the factory subs.
2. Does the Mach 460 have 2 amps or 3? I can see the 2 amps in the rear but I don't see one under the fatory radio.
3. I am assuming I need the +5V Fixed-Voltage Regulator from radio shack, I just want to make sure that is not built into the Metra wiring harness.
4. If I did want to use an external to amp to run the factory speakers or aftermarket speakers where can I tap into the factory speaker wires?
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Sixer4Life
Sep 29, 2015 07:03 PM
treesloth
Sep 28, 2015 07:03 AM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
