Decent sub in a vert?
Old Feb 9, 2010 | 10:39 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
Default Decent sub in a vert?
I want to put a decent sub in my vert, but isnt it a waste without a vented assembly going from the trunk to the cabin?
Old Feb 9, 2010 | 10:58 PM
Iskwezm's Avatar
Iskwezm
i wouldnt say its a waste, but you will get more out of a sub by porting the sheet metal under the top folding area.I have a 4X14 port on mine
Old Feb 9, 2010 | 11:00 PM
NuclearMuscle523
Sounds like quite a procedure.
Old Feb 9, 2010 | 11:28 PM
Iskwezm's Avatar
Iskwezm
your only going to get what you put into it.toss a box in the trunk and then listen to all the rattles if its not vented
Old Feb 9, 2010 | 11:30 PM
NuclearMuscle523
Yikes........ What setup are you running altogether?
Old Feb 9, 2010 | 11:39 PM
Iskwezm's Avatar
Iskwezm
right now i have 2 Kicker L7's 10" with a 2000 watt amp D class powering them(i had it laying around)The box has about .8 cu ft to the rear and about 1.0 in the front ported through the rear.Im going to change the box and subs as soon as we get the new Phoenix Gold line in.I picked up a Eclipse AVN6620 dirt cheap before they went under and the door speakers are O2 Audio 3 way 8" components with RF 6X8 components in the rear powered by a 800 watt 4 ch.
Old Feb 9, 2010 | 11:42 PM
NuclearMuscle523
I wonder if I effed up putting 8" kickers in the doors.
Old Feb 10, 2010 | 12:28 AM
Iskwezm's Avatar
Iskwezm
those could be used as a mid bass if you expand your system.My 8"'s in the dooors are crossed over at about 180 hz.
Old Feb 10, 2010 | 12:52 AM
NuclearMuscle523
is that 60-180hz?
Old Feb 10, 2010 | 01:06 AM
Texas Stang 07's Avatar
Texas Stang 07
well i have a 20" port for my single 15" FI audio sub and here are some pics. i just put it in last week. its kinda off the wall and im sure you wont do this but hey i did. im not done with it yet cause im going to blue suede the whole trunk as soon as i have some more free time. i custom built this with a friend. I fiber glassed the whole trunk where the spare tire goes.
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
