do i have the right box/amp/sub combo?
hey guys. had this set up for a few months now. not rly happy with the sound though. my friend mentioned that i might have the wrong combo of components? so i ask do these go together?
rockford fosgate p3d412
SPECIFICATIONS
Dual Voice Coil
Impedance : 4-Ohms x 2
Power Handling (MAX) : 1000 Watts
Power Handling (RMS) : 500 Watts
Sensitivity : 85dB
Mounting Depth : 6.75"
Woofer Displacement 0.094 cu. ft. (2.66 Liters)
12" ford mustang single sub box
SPECIFICATIONS
High Quality 3/4 MDF Construction
Rear terminals
Color: Grey
Dimensions (WxHxDxRH): 15Ħħ x 13Ħħ x 12Ħħ x 6 3/4"
Internal Box Volume (Cubic Ft.) : 0.708
Weight: 16.5 ibs
kicker zx300.1
FEATURES
ZX Series Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 1 chan.
2 ohms: 300 watts x 1 chan.
Max power output: 300 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
LED power and protection indicators
Tuned Bass EQ (0-12 dB bass boost at 40
SPECIFICATIONS
Dual Voice Coil
Sensitivity : 85dB
SPECIFICATIONS
Rear terminals
Color: Grey
Weight: 16.5 ibs
kicker zx300.1
FEATURES
RMS Power Rating:
MOSFET power supply
300 watts on a 12 is a little low but it could be made to work. The other problem I would suspect is that after displacement of the woofer the box only has a little over .6 cu ft which is also a little small for a 12 and kickers tend to like a big box.
You could probably improve the signal a little with a new deck.
Lethaldosage423
Oct 19, 2015 12:12 AM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
