taking factory headunit out
Old Apr 1, 2010 | 08:34 PM
05pnygt's Avatar
05pnygt
Default taking factory headunit out
is this easy to do ? just picked up a pioneer avic d3 going to try and install tomorrow....
Old Apr 1, 2010 | 08:48 PM
red96v6's Avatar
red96v6
Very, very easy. Hardest part for me was disconnecting one of the wiring harnesses, I think the climate control one...
https://mustangforums.com/m_4489289/tm.htm
Old Apr 2, 2010 | 12:56 AM
05pnygt's Avatar
05pnygt
Ok cool I also bought that ford PAC replacement radio interface so I shouldn't have to sodder anything like in that writeup right?
Old Apr 2, 2010 | 06:51 PM
red96v6's Avatar
red96v6
I didn't use that, but... Looking at the pictures of the PAC, it appears that you are going to have to solder the speaker wires, the ground, accessory and power, parking brake, mute, and dimmer like you normally would... I think the only point in the PAC is to let you keep all stock functionality, like the speed volume and maybe the auxiliary jack in the center console.
However, you won't have to cut any of your factory harnesses, which is a big plus.
I think this is the one I used:
http://www.crutchfield.com/p_1207055...tab=review#tab
Cheap and worked perfectly for everything I wanted. Works with my Shaker 1000 just fine. Just throwing this out there in case you might want to save some $$.
If you use the one I used, you have to wire in a 5V regulator....You probably don't have to do this step with the PAC...
Old Apr 2, 2010 | 11:50 PM
ttocs's Avatar
ttocs
you will need to connect that interface to the radio hrns some way. This is just one step under rocket surgery as you have to connect the red wire to the red wire, yellow to yellow, ect. You do not have to solder if you do not want to as crimp connectors are much easier and also acceptable.
I assume this is going into a shaker system?
Old Apr 15, 2010 | 03:50 PM
05pnygt's Avatar
05pnygt
Yes it's going in shaker system. Although Im putting in the pioneer ub310bt now tho
Old Apr 15, 2010 | 07:14 PM
ttocs's Avatar
ttocs
do NOT forget to connect the decks remote turn on(blue/white) to the hrns's amplifier turn on(blue)
Granatelli Sales
Jan 20, 2020 12:34 AM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
guitarman376
Oct 11, 2015 01:47 AM
Sep 17, 2015 07:57 PM
