amp,diming lights
Old Jan 7, 2011 | 10:35 AM
86 newbie's Avatar
86 newbie
Default amp,diming lights
ok so i have a 86 mustang gt, i just put a Sony xplod amp 600 watts bridged. i have a kicker 10 inch sub woofer. i have the amp turned all the way up and when i turn on my lights they dim with the bass also the radio does too. when the lights are off the radio doesn't dim. is this normal?
Old Jan 7, 2011 | 01:09 PM
Iskwezm's Avatar
Iskwezm
Why is your amp turned all the way up? Your alternator cant handle the load so its drawing from the battery.
Old Jan 7, 2011 | 01:20 PM
86 newbie's Avatar
86 newbie
because it sounds better i could turn it down but i thought it sounded better
Old Jan 10, 2011 | 09:00 AM
d.girardi's Avatar
d.girardi
A capacitor might work. If not then a new, more powerful alternator. If you go the capacitor way, for your system I would get a 1 farad. That means its good for up to 1000 watts
Old Jan 11, 2011 | 02:38 PM
AudioNutz's Avatar
AudioNutz
It is now widely accepted that capacitors do not (and can not) have any affect on Car Audio.
Old Jan 12, 2011 | 09:38 PM
86 newbie's Avatar
86 newbie
soo is there anything i can do, just change the alternator??
Old Jan 13, 2011 | 12:13 PM
AudioNutz's Avatar
AudioNutz
Move the power source closer to the amplifier. (Hint: The alternator isn't the power source.)
Old Jan 13, 2011 | 08:44 PM
86 newbie's Avatar
86 newbie
move the battery???
Old Jan 14, 2011 | 05:25 AM
ttocs's Avatar
ttocs
first, turn the gain down on the amp, it should not be above 3/4 full.
I would start with a better battery first, bigger alt 2nd.
Old Jan 14, 2011 | 01:37 PM
TC3K101's Avatar
TC3K101
What gauge wire do you have ran to the back? Also how is your ground wire? Did you sand the metal down and bolt it down or did you just philip screw it down? You should defiantly not be maxing out your gains. Also look into something called the big 3 first. Maybe throw a small battery in the rear like a Kinetic hc600 or something like that.
