Odd Situation-- Need Help!
Old Feb 1, 2011 | 01:33 PM
TowleC's Avatar
TowleC
Default Odd Situation-- Need Help!
Well, my friend recently purchased two used subs from a friend that we work with. They are Rockford Fosgate 15" P2s. So, we went to a local audio shop to buy an amp, and they told us that they were two different subs. One is a 4 ohm, and the other is a 2 ohm. He said that you could use one amp and run it at 3.33 ohms, which i have no idea how that would work. He recommended the Boston GTA800m, but i was wondering what you guys thinks he should do?
Thanks in advance
Old Feb 1, 2011 | 08:17 PM
todd217's Avatar
todd217
i would never use subs with two different impedance on the same channel of a amp. here is what i would do. first go the ebay and pick up two phoenix gold x100.2 amps or one x100.4. then build a box with dual chambers. those amps will make the same power at 2 or 4 ohms bridged. so what you end up with is both subs getting about the same power even though there are different.
Old Feb 1, 2011 | 10:49 PM
TowleC's Avatar
TowleC
Thanks. If he just got the x100.4 why would he need a 4 channel amp? Sorry I am kind of ignorant when it comes to car audio.
Old Feb 2, 2011 | 11:11 AM
todd217's Avatar
todd217
The x100.4 is a 4 channel amp.
Old Feb 2, 2011 | 12:00 PM
TowleC's Avatar
TowleC
Yeah okay I understand now, thanks for your help.
Old Feb 2, 2011 | 12:39 PM
todd217's Avatar
todd217
no problem
Old Feb 2, 2011 | 03:32 PM
TowleC's Avatar
TowleC
I actually have another question. How would I go about wiring it since it is a 4 channel amp with only two subs?
Old Feb 2, 2011 | 08:06 PM
todd217's Avatar
todd217
bridge it into 2 channels. it can be as simple as taking the + from one channel and the - from the other one.FYI not all amps will run at 2 ohms mono. i chose those amps for several reasons. they will do exactly what you need and are good solid amps.
Old Feb 3, 2011 | 11:36 AM
oldsch00lf00l's Avatar
oldsch00lf00l
Are you planning on running the 4 ohm sub on one channel and the 2 ohm sub on the other? If so, your 4 channel amplifier is going to be a wee bit expensive because most of them will not bridge to 2 ohms.
I also wouldn't recommend using subwoofers with a difference in impedance, but that is just me. In a mono situation using the Boston GTA800m with everything connected in parallel, the 2 ohm sub will draw more power than the 4 ohm sub resulting in a level mismatch between the two.
Old Feb 3, 2011 | 07:14 PM
todd217's Avatar
todd217
that is why i picked those amps. they run about a 100-150 for the 2 channel one and 200-250 for the 4 channel.
