Need help with sub
Hey guys, just got this box:
http://cgi.ebay.com/05-06-07-FORD-MU...#ht_3775wt_905
and I currently have this amp Alpine Mrp-650
http://www.crutchfield.com/S-sU1MXqw...-MRP-M650.html
and my question was would this sub be ok, 400 Watts RMS, 800 Watts Max
http://www.rockfordfosgate.com/produ...7&locale=en_US
any help would be appreciated it, also what would be the best way to wire the sub to the amp..sorry I know nothing about this..
For powering one sub you either need to use SVC to get the 4 ohm load from the amp or change one of them. This amp is too powerful for the sub and with a DVC setup you will be pumping 600 Watts RMS @ 2 ohm from the amp.
the reckfort website has a nice wiring wizard that will show you how to do the wiring. Here is the link http://www.rockfordfosgate.com/rftec...1&woofer_imp=4
Would this be a better choice of sub for the amp?
http://cgi.ebay.com/ALPINE-SWR-1043D...#ht_1618wt_905
Power wise this would be a good match with the Alpine amp. If you connect it like option 1 in this link
It will create a 600 watts RMS load @ 2 ohms.
I am not familiar with the type R sound quality but based in the sensitivity I’d look for something that is over 90 dB.
As far as getting 2 ohms or 4 ohms subs, there would be no deference as long as the power is matching with the amp. Most of the mono Amps support 2 ohms load and some even support 1 ohm load. If you decide on either 2 ohms or 4 ohms the most important thing is the wiring of the sub to the amp so you get the correct load and impedance.
Here is a nice link that will provide you with good information on power matching and wiring.
http://knowledge.sonicelectronix.com...amplifier.html
I hope this helps.
I hope this helps.
