MTX ts-85
Old May 7, 2011 | 03:12 PM
T8Stanggt's Avatar
T8Stanggt
Default MTX ts-85
Does any body else own this speaker? I have gone through 3 in the past 5 months. Has anybody else had issues with thus speaker as well?
Old May 8, 2011 | 12:12 PM
Blueper's Avatar
Blueper
I would recommend getting a different one when the warranty expires.
Old May 14, 2011 | 07:22 PM
ttocs's Avatar
ttocs
what amp are you pushin it with, and how are the gain adjustments on it(bass boost ect). If you are just running it off of the factory power then you know your problem.
Old May 31, 2011 | 01:25 PM
T8Stanggt's Avatar
T8Stanggt
I have the mtx te801D
Old Jun 14, 2011 | 10:11 AM
T8Stanggt's Avatar
T8Stanggt
Just went through another one!
Old Jun 14, 2011 | 01:33 PM
T8Stanggt's Avatar
T8Stanggt
Ok my amp is running 800 watts at 2ohms int speaker is 750 RMS. Hope this helps
Old Jun 14, 2011 | 05:30 PM
Blueper's Avatar
Blueper
Turn your gain down by HALF!
Old Jun 14, 2011 | 10:26 PM
ttocs's Avatar
ttocs
800 watts is alot of power for an 8.
Old Jun 15, 2011 | 08:57 AM
T8Stanggt's Avatar
T8Stanggt
The mtx ts-85 is a 12 inch sub
Old Jun 15, 2011 | 10:53 PM
oldsch00lf00l's Avatar
oldsch00lf00l
I never had good luck with square subs. I ran a 12" L5 then later a L7 only to have issues. Every time I had problems, it was usually adhesive failure at the corners where the surround would detach from the cone.
Also, that extra 50 watts RMS shouldn't be what is doing them in unless there is a problem with your settings be it gain or bass boost. I ran 1,000 watts RMS to a Digital Designs 1010 sub for about a year, and it survived. My sister is using it in her car.
