Wiring subs
Old Sep 6, 2005 | 01:46 AM
v6stang1335's Avatar
v6stang1335
Default Wiring subs
will an amp rated at 4 ohms power a sub rated at 8 ohms?
Old Sep 6, 2005 | 06:20 AM
02BlueKnight88's Avatar
02BlueKnight88
Default RE: Wiring subs
Yes....your amp will power the 8 ohm speaker. The ohms usually tell you how high of an ohm speaker you can attach to it, how many and it's also determined by how many watts it produces. In your case you could get away with two 8 ohm speakers, depending on how many connections on your amp you have. Just make sure the wattage capacity of your speaker isn't below the amount of watts you are gona pump through it with the amp. If you ever max out the volume on your stereo you run the risk of blowing the speaker if it can't handle the full amount of power that the amp can produce. If it is really under the wattage of the amp then you can run that risk at even lower volume levels from the max.
Old Sep 6, 2005 | 06:27 PM
bonesninja's Avatar
bonesninja
ORIGINAL: 02BlueKnight88
the number of connections on an amp has nothing to with how many speakers you can connect to it. for example if you have a mono amp that can be ran at 1 ohm and you have 6 dvc 4ohm subs you can use series parallel connections and end up with a 1.3 ohm load on the amp. to answer the original question-yes if a amp is rated at 4 ohms that means that any 1 speaker that is rated for 4 ohms or greater can be ran. for multiple speakers you must consider the ohm rating of each and then figure which wiring configuration will work.
http://mobile.jlaudio.com/support_pages.php?page_id=145 is a great site to explain wiring options.
watts are important too but not nearly important as loads. most ppl know when to stop turning it up just by listening to it.
Old Sep 6, 2005 | 06:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: bonesninja
That web site is okay but I noticed it only gives an overview of Parallel wiring options which WILL lower your OHM load. You could also go the other way. Series which raises your OHM load.
Series involves: Positive from amp to positive of the first speaker, negative from first speaker to positive of second speaker, negative of second speaker to negative of amp. If you have four 4OHM speakers you can wire them to a single Mono amp by using a combination of both wiring techniques and make the amp think there's only one 4 ohm speaker hooked up (See figure 3A of the link below).
http://www.termpro.com/articles/spkrz.html
Old Sep 6, 2005 | 06:40 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: v6stang1335
Yes but the output that is rated at 4ohm will roughly half (since 8 ohms has twice the resistance). THD will be roughly half as well.
Old Sep 7, 2005 | 08:27 AM
02BlueKnight88
You still can only connect so many speakers to one amp. It will only power so many speakers in a series parallel. That is what I was getting at when i was talking about connenctions...wrong choice of words but he didn't really ask about different ways too hook up his speakers so I figured i wouldn't get into that too much.
Old Sep 7, 2005 | 04:58 PM
sowaxeman's Avatar
sowaxeman
Retired Moderator
I must pick your answer apart on one point - the watts of the amp does NOT have to be equal to or less than that of the speaker. In fact, it is the opposite. You will MORE LIKELY blow a speaker by UNDER powering and driving too much THD (distortion) to the speaker!! Distortion blows speakers, not power - well, that and factored in with folks that think the input gain control **** equates to more power . I have always used more power out of my amp against what the sub is rated at. Just cross it over correctly, load the amp correctly (regarding ohms law, series or parallel, etc) and you will have a very clean low end spectrum!
Old Sep 7, 2005 | 05:32 PM
Derf00's Avatar
Derf00
Gentleman's Relish
I see why you responded the way you did but I try to give a full well rounded answer, otherwise some people think the options posted are all that exist and then they pull some other question out of their butt that is not related to the original post. I try to nip that stuff in the bud is all.
Old Sep 7, 2005 | 06:18 PM
bonesninja's Avatar
bonesninja
ORIGINAL: sowaxeman
never has a speaker ever been blown by under powering it. speakers can be blown by an amp clipping however. and yes power will blow speakers...not sure where your info comes from but i guarrantee you that there is not a speaker made that will not blow EVENTUALLY because you overpower it daily. for the most part--how much power it can handle is directly related to the enclosure it is in--especially subs. a big ported box does not need as much power to reach its thermal limits as does a smaller sealed box. you really should take some time and research your info before you cause one of these guys to blow their new equipment.
Old Sep 7, 2005 | 10:50 PM
02BlueKnight88
yeah...haha...what bonesninja said......blow a speaker by UNDER powering it......WTF!?!?![&:][>:][sm=grin.gif]
