Replacing my Mach 460 with a Double Din
I got a sweet deal on a brand new JVC KW-NT30HD. I am gonna be installing this into a 04 GT, replacing my 460 deck (that has started having issues about 2 weeks ago) I got the proper harness so I can use my stock speakers and amps, is there anything else I need to do the install? If anybody has some tips or a link, it would be appreciated!
check out page 2 of my cardomain page listed in my sig. Let me know what confuses you. The hrns's are different in my 94 to your car but the wiring is all the same. Depending on what your plans are for the stereo there are a couple of wiring options. Adding a sub later?
I am sticking with the stock speakers and amps for the forseeable future. The wiring is not what I have questions about, but actually getting it mounted to the car.
I put in a double din Clarion in my 01. I had no issues. Call Crutchfield and tell them you need a mounting kit.
The stock opening is slightly larger than an aftermarket headunit is and you will need a mounting kit.
Got the mounting kit, still waiting on the #^% harness adapter from Sonix.
Been going through the instructions for wiring the deck, specifically the GPS. I have to tap the speed sensor line. Anybody know what color wire that is?
