installing radio. need help
Old Aug 8, 2012 | 02:49 AM
Trays GT's Avatar
Trays GT
Default installing radio. need help
ok. I have a base model 2013 GT without sync. I am trying to install my Pioneer Avic-X930BT navigation. I ordered the Scosche double din install kit and the Scosche S3FD23 wiring harness. I hook up the Pioneer harness to the Scosche harness. Turn the key and radio will not come on. At this time I am checking my connections for the 3 main connections to turn a radio on. Ground from Pioneer to Scosche harness is correct and goes to car harness. Yellow constant power Pioneer to Scosche is hooked up correctly and goes to car harness. Red Ignition from Pioneer to Scosche is hooked correctly but I follow that wire and goes off or another plug that goes to a interface. At this time I didn't care if the steering wheel controls didn't work so I didn't order a interface kit. OK, So I see I need the Scosche S3-1 Interface module and steering wheel module. This is what my extra plug plugs into that carries my red ignition wire. Now I have to wait till that comes in to try installing again. My question now is I have searched and searched forums and google for the answers with no luck. Where and what do I need to tap into for the VSS wire and also for the REVERSE SIGNAL wire. I really want to hook them up to make everything right and correct. Anybody please?
Posted from MustangForums.com App for Android
Old Aug 8, 2012 | 08:56 AM
mybeststangever's Avatar
mybeststangever
Default Install avic x930 to 2013 mustang
Hi, the 930's vss should be the pink wire coming from the avic's harness, connect this to the pink vss wire coming from the scosche.
The reverse wire from the 930 is the violet/white coming from the harness, connect this to the violet/white wire from the scosche. If you look very close, the scosche wires are marked with their functions with writing on the wires.
If all is wired correctly, and the avic is a properly working unit, it does not need the sw interface to work.
Also I assume you have looked into the avic x930bt bypass.
Good Luck
mtgldr
Feb 3, 2024 09:00 PM
unit91
Sep 15, 2015 09:53 AM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
