My 2011 GT speaker upgrade
I didnt use an adapter and didnt cut any wires. I stripped some of the shielding from the + and - wires going to teh stock connector and cut a section of my home wire and wrapped it around the bare wires fron the car.
and then wrapped it in wire tape.
http://www.facebook.com/media/set/?s...type=3&theater
this is my step by step to installing the pioneer subs. just make sure you click each link in order.
I used a strong utility knife to do the cutting. Also only 2 of the holes lined up from sub to door. For the other holes I used the screws provided with the subs and made new holes. they screwed in fairly easy.
I've got the same question. I have the base model without the sub ports so I guess my two options are:
1). Find two door skins from a wreck that already has the ports for the Shaker system.
2). Cut the holes myself which may end of destroying the door skin.
Any work arounds?
Any work arounds?
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
