Mach 1000
Old Mar 2, 2013 | 04:25 PM
chillindamost's Avatar
chillindamost
Default Mach 1000
I am trying to figure out a battery draw coming from my mach1000 amps. I have a 2003 gt vert and when I was in the trunk I can see the tray with amps on it and then I noticed 2 more amps by the power roof motor on the floor. Is this normal???
I am guessing that one of the amps on the floor part may have gotten wet at some point(i can see external corrosion)can I disconnect just the amps on the floor and have the sound system work??
I thought the mach 400 system had the amps on the floor and the maach 1000 were in the tray, thus I am confused
Thanks for any help.
ed
Old Mar 3, 2013 | 12:17 AM
chillindamost
I figured out that they are subs for tweeters, I am going to disconnect and see if they are the culprit in my battery draw and if so i will open them up and try and find the problem and let you know.
Old Mar 11, 2013 | 03:25 PM
mustangman02232's Avatar
mustangman02232
mach 460 amps should be under the convertible well IIRC, and one under the center console, the 1000 adds the shelf I believe
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
