Audio System Help
Old Jun 12, 2014 | 06:52 PM
dragonstorm's Avatar
dragonstorm
Default Audio System Help
I have been searching as many websites as i can find. I am trying to figure out what size speakers for the front doors and the lower speakers in the back on a 2003 vert, with mach audio system. every time i find something its a different size.
Old Jun 12, 2014 | 07:33 PM
dragonstorm
Also i have some blown speakers, so I need to replace them, But after reading all these post it would seem i cant use aftermarket speakers because of the mach 460 system, is that correct? If so is there a work around so i can replace the speakers? i have a aftermarket HU also.
Old Jun 13, 2014 | 12:25 AM
ticopowell's Avatar
ticopowell
You should be able to use aftermarket speakers, check crutchfield, they should be willing to tell you the right size and sell you speakers that work fine. my guess is that they are 5x7/6x8 speakers... those are usually about the same size and fit in the stock mounting spots for newer mustangs, but I don't know for sure on the size.
Old Jun 13, 2014 | 05:06 AM
dragonstorm
i thought the mach systems had different ohm speakers and what not? im new to this system is why im asking
Old Jun 13, 2014 | 07:31 AM
dj2014's Avatar
dj2014
Go to Crutchfield and click on the "Outfit my car" link. For your 2003, it shows---
"◦Front Door: 5x7"
Far Rear speakers
◦Rear Seat Side Panels: 6-1/2" Your factory speaker doesn’t match any aftermarket speaker size exactly. Here, we list the largest speaker that will fit in the factory location. As you shop, we’ll show you all options for this location.
◦Trunk: SUB BOX Your factory speaker doesn’t match any aftermarket speaker size exactly. Here, we list the largest speaker that will fit in the factory location. As you shop, we’ll show you all options for this location."
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
