Amp/Speaker problem?
Old Nov 29, 2005 | 03:11 AM
bonesninja's Avatar
bonesninja
Default RE: Amp/Speaker problem?
ORIGINAL: rob_boura
hey bro sorry bout the dis agreement but to each his own oppinion i ll hit you up im in tx rite now ill be round round the holidays by the way by the way how old r u and i may know you or you may know my cuzin
agreed -- to each his own--but i'm 33 but still 16 at heart. btw i'm also medically retired army.10 years.
Old Dec 2, 2005 | 02:31 PM
HAMMER108's Avatar
HAMMER108
Your speakers/amp are "clipping". You are trying to push the amp to hard and its causing the speakers to pop. You need to check the electrical lines and make sure your alternator/battery are okay. Check your grounding points. Clean away any painted surface to bare metal.
Good luck. I had the same problem now its gone.
Old Dec 2, 2005 | 04:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: HAMMER108
+1 ^^^^
You could also use a Cap if you're not already to help and check out what guage wire you are using. If the power draw is too great for the guage wire you are using or the peak power current needs cause a drop in line current, the Cap will help.
Old Dec 4, 2005 | 01:30 PM
bonesninja's Avatar
bonesninja
or maybe......maybe you have your amp overloaded. what impedence and how many voice coils? are you wired for 4 ohms, 2 ohms, 1 ohm? is your amp stable for that ohm load? same problem could happen if you have a 2 ohm stable amp and have the subs wired for 1 ohm load.
Old Dec 7, 2005 | 12:23 AM
seight311's Avatar
seight311
True^ Definatly something to check as well
Old Dec 8, 2005 | 12:52 AM
billyvk10's Avatar
billyvk10
very new here but thought i would add. if it is a four channel amp and you have two channels bridged to each woofer the final impedence of each woofer has to be at least four ohms. almost every four channel amp will be two ohm stable but that is per channel. two channels bridged at four ohms makes splits the impedence to each of those channels. if there dual four ohm woofers there probably seing two ohm mono to each pair of channels.....=1 ohm per channel......too low. i have worked in this industry for about 6 1/2 years in indiana so far and that seems to be the most common prob with running a four channel amp on two woofers. good luck
Old Dec 10, 2005 | 01:31 AM
F00Mustang's Avatar
F00Mustang
pesrsonal pref would be lightning i know its a walmart no name
You do know that Lightening audio is the made by Rockford Fosgate right?
Old Dec 10, 2005 | 10:41 PM
seight311's Avatar
seight311
^Exactly why I asked him.
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
