Stereo install help needed
Old Jan 8, 2006 | 09:29 PM
Rhyknow98stang's Avatar
Rhyknow98stang
Default Stereo install help needed
Hey everybody, i'm new here so go easy on me. I have a 98 v6 without the mach system and i removed the H/U tape player and separate CD player. Now i'm having trouble installing an aftermarket Pioneer H/U. I probably got the wrong wiring harness because the harness has 4 plugs on it. A 6-wire plug for the power and ground, etc. An 8-wire plug for the speakers. A 4-wire plug branching off the 6-wire plug and another small 8-wire plug branching off the larger 8-wire plug. The only plug i've connected successfully is the 6-wire plug for the power. All of the other stock plugs are totally different sizes from the plugs on the harness that i bought. And i've heard some things about a stock amplifier but i don't really know what's going on with that. With all that said if anyone could lend some info, any help would be appreciated.
Thanks a lot
Rhyknow
Old Jan 8, 2006 | 11:22 PM
seight311's Avatar
seight311
Default RE: Stereo install help needed
What kind of cd player did you get?
Old Jan 9, 2006 | 02:41 AM
TimmyGt's Avatar
TimmyGt
The Mach sound system uses an external amp (I think its located in the trunk or by the back speakers). You need a diffrent harnes for what you got. You got the one for the base radio. You will also have to bypass the external amp other wise you will be amping a amped sorce (good bye speakers). If you need more help let me know!
Old Jan 9, 2006 | 11:08 AM
Rhyknow98stang
Thanks a lot
Old Jan 9, 2006 | 11:37 AM
pj1010's Avatar
pj1010
ORIGINAL: TimmyGt
Uhhhh..he just said he didn't have the Mach.
Old Jan 9, 2006 | 02:36 PM
TimmyGt's Avatar
TimmyGt
thanks for pointing that out. I didnt look that close. but he would still have an external amp if he has both the tape deck and the cd deck.
ORIGINAL: pj1010
ORIGINAL: TimmyGt
Old Jan 15, 2006 | 09:30 PM
Sickspackstang's Avatar
Sickspackstang
there should be 2 square shaped harnesses and a long rectangal harness. 1 is 6 prong (amplifier), the other is 8 prong (speakers), and the other long one is for power ground etc.
djbigskrilla
Sep 20, 2022 01:04 AM
Fast-Hands
Aug 19, 2015 06:54 AM
defarmer
Aug 13, 2015 06:40 AM
pjrolvrz
Aug 10, 2015 02:10 PM
pjrolvrz
Aug 10, 2015 01:39 PM
