front bass driver side speaker issue
Old Jan 13, 2006 | 07:10 PM
Smooth_J's Avatar
Smooth_J
Default front bass driver side speaker issue
Around a couple of months ago I started to have issues with my front bass driver side speaker in my mach 460. (I narrowed the speaker down via bal and fade) It started to rattle, make static noises and such and it has got worse over time. I finally had the change to take out the speaker and visually it looks just fine. There are no holes in the cone and the connection seem to be pretty solid. Could it still be the speaker?
Please help?!
Old Jan 14, 2006 | 12:33 PM
Sinister Audio's Avatar
Sinister Audio
Default RE: front bass driver side speaker issue
ya it is probaly unwinding the coil on the inside. push down a little bit on the cone and see if it makes a scratching noise. im sure its junk.
Old Jan 14, 2006 | 02:15 PM
Smooth_J's Avatar
Smooth_J
I tried that and it does
I called up the ford dealer and another one will cost 43 and change. I wanted to upgrade, but I just do not have the money to do so right now.
Thanks again all
Old Jan 14, 2006 | 03:14 PM
Sinister Audio
you can get some aftermarkets like bravox or arc for under a 100 for a pair and it would be a ton better than factory.
Old Jan 14, 2006 | 03:24 PM
Smooth_J's Avatar
Smooth_J
Would I have to change the HU or the amps since I am changing the speakers?
Old Jan 14, 2006 | 04:11 PM
Sinister Audio
no they would still work just changing the speakers. i have done it on alot of other cars. some GM you have to watch but ford is pretty good about it.
Old Jan 14, 2006 | 04:58 PM
Smooth_J's Avatar
Smooth_J
Any particular model? Or would any model work?
Old Jan 14, 2006 | 05:28 PM
Sinister Audio
ajust about any model will work just as long as they are the right size.
Old Jan 15, 2006 | 04:22 PM
HACorona's Avatar
HACorona
Pop off the black panel that holds the window and door lock controls, there should be two screws holding a bracket on there. Tighten those or use some threadlock. Problem solved.
Old Jan 15, 2006 | 11:08 PM
pj1010's Avatar
pj1010
ORIGINAL: HACorona
What?? Was that a joke?
