Radar
Old Jan 16, 2006 | 11:24 PM
BlackSVTsnake302's Avatar
BlackSVTsnake302
Default Radar
http://www.cardomain.com/item/COBESD7000
What do you guys think about that? should I get a higher end Cobra radar, or somthing else like pasport? thanks guys
Old Jan 16, 2006 | 11:46 PM
BlackSVTsnake302
Default RE: Radar
C'mon some1?
Old Jan 17, 2006 | 12:02 AM
Birdieman4's Avatar
Birdieman4
Default RE: Radar
I say don't waste your $ on a Cobra. I have used Whistlers, Cobras, and a few other off brands. If you are gonna spend the $, I say buy either a passport, Valentine, or a high end Bel. I use a passport and wouldn't swap it for anything.
Old Jan 17, 2006 | 12:03 AM
pj1010's Avatar
pj1010
Default RE: Radar
In the grand scheme of avoiding a ticket, is a more expensive one going to have any beneift?
Old Jan 17, 2006 | 12:48 AM
Birdieman4's Avatar
Birdieman4
Default RE: Radar
Absolutely.
Old Jan 17, 2006 | 01:40 AM
pj1010's Avatar
pj1010
Default RE: Radar
How so? The less expensive one will give you enough warning to slow down to the speed limit. With instant on, you might not even get a warning.
Why speed anyway? How much time do you make up? The acutal time saved with speed a decent amount is fairly small. On a 25 mile trip, you'd have to go 10 over the whole way to save a whoping 4 minutes. Unless you are doin like 20 over all the time, it just seems silly.
Old Jan 17, 2006 | 01:49 AM
BlackSVTsnake302
Default RE: Radar
I think the real reason for a most expensive one is that the pick up more, the less expensive one might not always pick them up, and I never spend, only once inawhile I just think its somthing nice to have.
Old Jan 17, 2006 | 02:05 AM
fastsilverstang's Avatar
fastsilverstang
Default RE: Radar
V1 is #1
Old Jan 17, 2006 | 02:15 AM
Birdieman4's Avatar
Birdieman4
Default RE: Radar
Here is what is important to me in a radar detector. 1.) I like to have an audio distinction between all the different radar bands, so I don't have to look at the detector if it goes off. Often times cheaper radar units don't have this. 2.) It needs to have excellent range. Guys, it makes a difference, especially on the freeway. Better units can pick up radar at well over twice the distance of cheaper ones. Hey, if I'm goin 110 on the freeway, I need that distance. 3.) It can't give me too many false alarms. Better units have better filter systems to help this. 4.) It needs to have a loud volume setting. I like to listen to music when i drive, sometimes very loud. Often times I have found cheaper units simply won't give me a loud enough alarm. the better ones, like the passport, have programmable settings, allowing for a really loud alarm if you want it.
Old Jan 17, 2006 | 09:32 PM
Ebein's Avatar
Ebein
Default RE: Radar
V1 all the way, the arrows and counter have saved my **** more times than I can count.
