AutoBadges.com Your #1 Source for V6 and V8 Mustang Emblems. If you are looking for more of a styling look for your car or just want a custom badge made to stand out, AutoBadges.com is the shop for you!
My Order..
Old Mar 21, 2007 | 01:17 PM
flash20's Avatar
flash20
Default RE: My Order..
they all fit the same
Old Mar 22, 2007 | 01:32 PM
mustangman02232's Avatar
mustangman02232
take a pic of the CAI, if it has a 90* bend then your right it wont, it should have a nice little 45*ish bend it in from the MAF to the TB which was changed in 01 when they redid the upper intake and got 3 more HP and 5 more ft.lbs, the difference between the 3.8 and the 3.9 (really a 3.825L) is just a slightly longer stroke because ford wanted to get rid of the bad rep of headgasket failure that has stuck with the 3.8 even though it was fixed in mid way 96. autobadges has great customer service if something is wrong, but i think its more of the it says 3.8 it automatically wont fit thing
Old Mar 23, 2007 | 07:10 PM
Insanestang's Avatar
Insanestang
Here is my stock intake:
Here is the MAC CAI i got:
My MAF cant bolt onto the MAC CAI i got.
Old Mar 23, 2007 | 07:33 PM
mustangman02232
it will fit just fine, get it installed
Old Mar 23, 2007 | 07:35 PM
Insanestang
how will it fit fine if the MAF is nothing like it sould be?!
Old Mar 23, 2007 | 07:38 PM
Autobadges.com's Avatar
Autobadges.com
Banned
The MAF bolts to the turned pipe and you use the blue hose to CLAMP the other pipe to it..its how ALLLLL MAC CAI's or any intakes for that matter are installed
see:
Do you even know what a MAF looks like???? That big black piece is NOT your MAF, you MAF is INSIDE of it...here is what it looks like and you can see it in the picture above, where it goes and HOW it goes. Please TRUST ME when I saw its the perfect kit!!
Old Mar 23, 2007 | 07:55 PM
Insanestang
So so i have to take my MAf out of the case its in and buy the adapter to bolt it into the CAI?
Old Mar 23, 2007 | 07:59 PM
mustangman02232
you dont need an adapter, the MAF goes right over it, just take it out of the plastic thing
Old Mar 23, 2007 | 08:01 PM
gill7784's Avatar
gill7784
Yes, take the MAF out of the black case. The flanged part of the lower tube (the one that insets into the fender well) bolts to the flanged portion of the MAF with 4 bolts and nuts. I personaly like to use some black permatex to make a nice gasket between the MAF and fender portion of the CAI. The BLUE tube connects to the rounded end of the MAF with the supplied (I assume) hose clamp. It's pretty darn simple. Just make sure the MAF is at a 90 degree angle to the bottom of the car. Don't forget to plug the MAF back in and you should be all set.
Old Mar 23, 2007 | 08:03 PM
gill7784's Avatar
gill7784
Oh yeah, it's also a good idea to disconect the neg (black) lead on the the battery for 20 minutes to reset the computer. This will ensure you get the fullest gain from your new CAI.
