efi intake help
Old Nov 17, 2013 | 04:24 PM
88-347stroker's Avatar
88-347stroker
Default efi intake help
guys need advice on new intake to go with my 75mm tbody on a 347,i was thinking trick flow street burner it has a 75mm opening
Old Nov 17, 2013 | 04:32 PM
clowe1965's Avatar
clowe1965
Can't say, I'm still running a carb setup. How does that match up to your cam power band? I'd be more concerned with that than the throttlebody side.
Old Nov 18, 2013 | 07:54 AM
88-347stroker
Cam comes in around1800-5800,intake is rated idle -5500,since the car will never see the track it looks like a good match
Old Nov 18, 2013 | 08:15 AM
clowe1965's Avatar
clowe1965
Was the intake rated for a 347 or a 302? If its a 302 then I'd say its a good match since the cfm requirements will bump up, specially since its not for the track.
Old Nov 18, 2013 | 11:49 AM
88-347stroker
It said for 5.0 not 347,overall here is what I have for a package maybe some overall input may help-347, trick flow intake ,75mm tbody and ego spacer ,30 lb injectors , bbl cold air with maf rated for 30 injectors , bbl shorties ,bbk off road x pipe , flowmaster cat back American thunder , did maf conversion.Am I on the right track for a good sound "street rod"
Old Nov 18, 2013 | 12:52 PM
clowe1965's Avatar
clowe1965
Yeah it seems so. I've heard that having a bit of back pressure is preferable for the engine in n/a form so don't go too big on the exhaust pipe. Still the stock 302 cam?
Old Nov 18, 2013 | 04:58 PM
88-347stroker
no stock cam here :
roller cam
.543 intake
.554 exhaust
218 intake/ 226 exhaust duration @ .050-112 degree lobe separation
she has a nice chop to her
Old Nov 18, 2013 | 06:30 PM
clowe1965's Avatar
clowe1965
Video!
Old Nov 19, 2013 | 04:37 AM
88-347stroker
how do I post a video
Old Nov 19, 2013 | 05:50 AM
Sleeper_GT's Avatar
Sleeper_GT
You would have to post it to YouTube, for example, and then post the link.
