Gear Ratio
Old 01-03-2014, 05:44 PM
Vosker
Vosker's Avatar
Default Gear Ratio
Whats the difference between like 3.73 or a 4.10 can anyone help me? I want the best gears
Vosker is offline
Old 01-03-2014, 05:48 PM
CPTCO
CPTCO's Avatar
I went with 4.10s and have never looked back. My car is running about 2200 rpm at 70 and 2400 or so at 80. I'm getting about 21 mpg average. I have TONS of low end power, and the car will still go way faster than I want to drive it.
CPTCO is offline
Old 01-03-2014, 05:50 PM
Vosker
Vosker's Avatar
like what do the numbers mean?
Vosker is offline
Old 01-03-2014, 07:13 PM
alan0614
alan0614's Avatar
Found this for you -
The term gear ratio simply means the ratio of # of teeth between two meshing gears. In a system where two gears mesh together, one of the gears will have power applied to it (the drive gear) and the other gear (the driven gear) will be turned by the drive gear.
The ratio is simply the number of teeth on the driven gear divided by the number of teeth on the drive gear. In the case of rear axles, the pinion gear (the drive gear) has X number of teeth and the ring gear (the driven gear) has Y number of teeth. If we divide Y by X (Y/X) then we get the gear ratio.
For example, a ring gear that had 43 teeth and a pinion that had 11 teeth would be a gear ratio of 3.916 (~3.92). A ring gear that has 39 teeth and a pinion that has 11 teeth would have a gear ratio of 3.545 (~3.55).
alan0614 is offline
Old 01-03-2014, 07:39 PM
Vosker
Vosker's Avatar
Well so what would be the best one I'm thinking about going with 3.73 gears
Vosker is offline
Old 01-03-2014, 08:38 PM
alan0614
alan0614's Avatar
What do you have now?
alan0614 is offline
Old 01-03-2014, 09:08 PM
clowe1965
clowe1965's Avatar
Stock v6 auto has 3.27s. Get the 4.10s. Actually scrap getting gears and get a used 8.8 Axle with 4.10s already in it, then you'll have an LSD instead of a one wheeled wonder.
Buy this, bolts right in and cost the same as a gear swap anyway.
http://charlotte.craigslist.org/pts/4229436595.html
clowe1965 is offline
Old 01-03-2014, 10:01 PM
Vosker
Vosker's Avatar
they don't have it for the 03 V6 :/
Vosker is offline
Old 01-04-2014, 07:38 AM
CPTCO
CPTCO's Avatar
It should fit. But you've come to the right place, Alan and Clint will help you get the right setup.
CPTCO is offline
Old 01-04-2014, 07:30 PM
Vosker
Vosker's Avatar
I'm just gonna go with 4.10s
Vosker is offline
Quick Reply: Gear Ratio
