Need help with photofilter
well youd have better luck searching
"photofiltre" than you would searching "photofilter"
since you dont have layering capabilities, youd have to just lasso the car, and change the hues around. i dont remember the names of the all the color adjustment menus in photofiltre anymore, its been a like 3 years since ive used it.
i chop the sections i want to paint, excluding the things i dont want to paint, then go to adjust, then color balance, and mess around with the dials till i find a color i like. Then i write down the numbers of the color, and chop out the next section of the car and put the same numbers in for that section. I bet there is an easier way, but thats how i do it.
when you lasso youre car, (i think photofiltre does it too) you can probably hold Alt to deselect, or hold shift to add to your selection.
since there's quite a few people using the program now, someone should make some tutorials when you get a hang of the program, since it does vary from photoshop quite a bit.
if i think of it sometime, ill download it myself again and use it for reference. i knew my way around the program pretty good... but its been a few years since ive used it.
