NEED A SIG
Old May 17, 2008 | 10:11 PM
03GT CONVERTIBLE LOU's Avatar
Default NEED A SIG
HELLO NEED A SIG DO WHAT EVER YOU WANT. The attachment is bigger if you could use that one so it fits within forum rules.
[IMG]local://upfiles/96019/9A59FC23BC9F4C008E6E508F88C4204D.jpg[/IMG]
Old May 19, 2008 | 01:57 AM
7_Zero's Avatar
7_Zero
Default RE: NEED A SIG
Will this suite your fancy?
[IMG]local://upfiles/87520/A895C073F472465CAB14852C1EFFCC55.jpg[/IMG]
Old May 19, 2008 | 07:43 AM
looks good. Ok tried to save it in paint tried to resize it won't change into sig help!!!!!!!!!! tell me how in a special education way so that I can do this Thanks!!!!!!!!!!!!!
Old May 19, 2008 | 12:18 PM
7_Zero's Avatar
7_Zero
How much bigger did you want it? Its 500x200 right now, which seems to be what alot of people are using. I can tell you howto resize it, but it will lose quality.
Open it up in paint...then go to the 'Image' drop down menu. Select 'stretch/skew' then enter the percentages in the Stretch- horizontal &verticle section. Keep the numbers equal otherwise you will skew it and it will look funny.
Like I said, it will lose quality because of the size so if you want I can enlarge it for you since I still have the larger version.
Old May 19, 2008 | 01:10 PM
Joolander's Avatar
Joolander
Lord High Protector
maximum size is 500x250[>:]
Old May 19, 2008 | 03:37 PM
PennState's Avatar
PennState
yeah thats the biggest u can have it...
Old May 19, 2008 | 03:55 PM
Thanks fellas I will do that.
Old May 19, 2008 | 05:45 PM
Ok my avatar was no problem to change but the sig is another issue I saved sized it did all that and I still don't see in my sig. What else do I need to do?
Old May 19, 2008 | 06:45 PM
7_Zero's Avatar
7_Zero
I haven't put up a sig before, but I believe you have to have it hosted somewhere to get it to work.
Old May 19, 2008 | 08:01 PM
ORIGINAL: 7_Zero
Thanks man. does anyone know how to host a sig?
