simple gif animation help
Old Feb 18, 2010 | 11:09 AM
antiv6's Avatar
antiv6
Default simple gif animation help
Can someone make me a gif animation like the one i made without the trailing car behind it as it moves. At least 12 frames, thanks!
Old Feb 18, 2010 | 11:24 AM
Xeno's Avatar
Xeno
'Dr. X'
unless someone gets to ya first, i can do it later this afternoon or this evening
Old Feb 18, 2010 | 11:28 AM
antiv6's Avatar
antiv6
appreciate it, theres no rush i just need it by tomorrow night for school, the teachers example didnt teach how to get rid of them
Old Feb 18, 2010 | 07:29 PM
Xeno's Avatar
Xeno
'Dr. X'
here ya go. btw, what program are you using? i can explain how i did it if you'd like
Old Feb 18, 2010 | 10:31 PM
antiv6's Avatar
antiv6
we used gimp which ive never used utill today, i usually use photoshop, if you could explain that would be great. Thanks for the help!
Old Feb 18, 2010 | 11:34 PM
Xeno's Avatar
Xeno
'Dr. X'
with photoshop, have two layers (the car and the background). with the car layer as the top layer, place it at your 'starting point', then (without flattening the image) go to 'save as', select .jpg as the file type, and name is _____-1. then, go back to the layered image, and move the car layer to the next position; save as .jpg with the name _____-2. go back, move to the next position, save as .jpg with the name _____-3. repeat this process until you get the car layer to the final position.
now, open all of the .jpg files you just created, then copy and paste them in order into one file (numbering the files you made helps keep this process organized). so, _____-1 will be the bottom layer and _____-final# will be the top layer. finally, go to 'save for web' and select the 'animate' check box, the 'loop' check box, and adjust the timing if needed (the process for your version might be a little different than this, though). hit ok to save and you should be done.
if it helps, open the .gif i created into photoshop and you should be able to see the 'layered' version.
if something doesn't make sense or if you have any other questions, let me know and i'll see what i can do to help
Old Feb 18, 2010 | 11:43 PM
thedarkside's Avatar
thedarkside
Wow thats bad ***, I always wondered how those were made... Good to know!
Old Feb 21, 2010 | 09:40 AM
ImpOnFire's Avatar
ImpOnFire
HRnB's Minion
teh wheels dont turn!!!! devil car!!!
lol
Old Mar 14, 2010 | 11:44 PM
katte's Avatar
katte
Testing Admin's Patience
Wow its great to see.But I'm sorry to say I don't know animation.But after seeing your post it has increased my curiosity.So I will definitely learn.
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
Brett Ludlow
Sep 23, 2015 06:59 AM
