help?
Old Mar 12, 2010 | 04:55 PM
mustangsinmichigan's Avatar
mustangsinmichigan
Default help?
okay' me and my buddy are trying to get my front fenders off. but the bolts just spin or feel like there locked up. i know there are bolts underneath' but nothing we try works. im actually out there right now' so if you have any advice text or call me... 517-260-6495 thanks. ill check back in a few hours...
Old Mar 12, 2010 | 06:22 PM
1slow67's Avatar
1slow67
ROTM Moderator
Well if you plan on getting new bolts you could just get a grinding wheel and cut them off. I had to cut off 2 of mine, but I'm replacing all of mine with new bolts and nuts.
If you were to go that route I would try under the fender before trying on top since you might get the fender a little as well.
I've also taken a set of channel locks and grabbed ahold of the Washer/nut thing and been able to loosen them that way.
Old Mar 12, 2010 | 07:08 PM
Gun Jam's Avatar
Gun Jam
The bolts along the top by the engine bay or the ones in the door jamb?
-Gun
Old Mar 12, 2010 | 07:47 PM
4reboy's Avatar
4reboy
well the bolts screw into the threaded clips, so I don't know how they could be just spinning unless the original hardware was replaced. Or the threads are damaged so when you try to undo it it slips and drops back in. If this is the case I would take a screwdriver under neath the bolt to put pressure upwards as you turn the bolt loose. This should help get it out.
But if your car still has some nice paint on it be careful with the screwdriver, I would put a towel underneath so as not to scratch
Old Mar 12, 2010 | 07:59 PM
THUMPIN455's Avatar
THUMPIN455
I get lots of them that spin, the clips or blind nuts break and it just spins. I end up cutting them off and replacing the clips or reworking the section at the bottom where the blind nuts go on some cars. I am really not looking forward to that on the GTO I am doing right now. You can really screw things up with a grinder or cut off wheel, so its best to take your time so you dont wreck a fender and have to replace it or do a bunch of welding on it to get it right again.
Old Mar 13, 2010 | 03:59 PM
mustangsinmichigan
thanks for the info. ended up that we just snapped most of them off. the farther into this car i get the more rust i find, at this point i might have to replace everything firewall forward. =/
Old Mar 13, 2010 | 06:52 PM
THUMPIN455's Avatar
THUMPIN455
Welcome to the club! Always remember, it could be much worse!
Old Mar 13, 2010 | 08:12 PM
mustangsinmichigan
the whole body could look like swiss cheese..... the middle of the car is fine"ish" but everything else willl prolly need be replaced.... good 10 year project =/
Old Mar 15, 2010 | 07:37 AM
69FB's Avatar
69FB
I bought what I thought was a running driving car in 2008. Mine is still in the shop torn down and still finding "little things". It's just the nature of these cars. Good luck with your project.
