MSD electronic ignition
Old Feb 27, 2011 | 03:43 PM
lucasp's Avatar
lucasp
Default MSD electronic ignition
has anyone installed one in a I6 before? does it make a huge difference? please chime in if you have and a pic would also be great for install location.
ThanX,
Old Feb 28, 2011 | 03:43 AM
tx65coupe's Avatar
tx65coupe
This is just my two cents. I would go with a Pertronix Ignitor and keep the factory distributor. That will eliminate the points and should make the car run better.
The MSD is not going to do much if anything for your application. I don't care much for MSD anyway.
Old Mar 1, 2011 | 01:12 AM
PaulS's Avatar
PaulS
ThanX,
The biggest difference will be that you don't have to change points anymore. It may start a bit easier but rolling down the road you won't notice a thing. If it should fail you better be carrying a spare unless there are a lot of places around you that carry them in stock. At least with points, if they fail you can adjust thenm and be on your way.
Old Mar 1, 2011 | 04:29 AM
kalli's Avatar
kalli
aye.
- get a pertronix ignitor.
- have your distributor recurved to spec
- set timing
job done. would be the same opinion here
Old Mar 1, 2011 | 10:12 AM
hightower2011's Avatar
hightower2011
I agree with the Pertronix ignition. The guy I bought my engine from explained it to me and how it was better than MSD, so I'm going with the Pertronix. Nor do I won't to drop more money on an MSD anyways.
Old Mar 1, 2011 | 11:21 AM
mr_velocity's Avatar
mr_velocity
Better......
$85,000 per motor, look between the 2 blowers and you'll find a blue MSD 6M box (rev limited is stuffed in there too). They're 1550hp on race fuel or 1150hp on pump gas with a mere 1100ft/lbs of torque and they'll run ***** out for hours at a time, they're not 1/4 mile drag motors.
Just razzing ya, you know I need to do this at least once a day , Pertronix is fine in our applications. I'll be running a msd dual ignition setup like we ran in our race boat.
Old Mar 1, 2011 | 11:33 AM
hightower2011
Haha I agree, I'm sure THOSE motors deserve more than the pertronix.
On the other hand, for me....
I mean, once I get my 1,000HP engine up and running, MAYBE I'll use that MSD stuff.....
Old Apr 27, 2011 | 01:20 AM
DenDen's Avatar
DenDen
Ya pertronix is awesome on an I6.I have had an MSD module crap out on the highway.Didnt like it.MSD only works below 3000 rpm(read the manual).The only gain I can see is the rev limiter and all the other things like crank triggers.The multiple spark is debatable.
Old Apr 28, 2011 | 02:11 PM
mustangted's Avatar
mustangted
HAD 2 PRETONIX fail with out warning. did not enjoy the walk home.
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
firehorse02
Nov 16, 2015 11:28 AM
piotrek53
Oct 13, 2015 06:54 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
