My 1971 Mach 1
Old 01-21-2012, 11:37 PM
Bosko
Bosko's Avatar
Default My 1971 Mach 1
All, I started a blog about my 1971 Mach 1 a year or two ago. I am making very slow but somewhat steady progress. Right now my focus is upgrading the suspension using the roller kits on upper and lower control arms from Open Tracker Racing, and the roller spring perch mod from Daze.
Pictures and some thoughts are here:
http://boskomustang.blogspot.com/
I'm new to this blogging thing, so the format and readability are not what I want, but you can at least follow along for a bit.
Happy building!
Bosko is offline
Old 01-22-2012, 02:36 AM
andrewmp6
andrewmp6's Avatar
Looks pretty good so far but btw you don't do a Shelby drop on a 71-73 car ford already lowered the upper a arm started in 71.Ford also changed to a gm style steering box in 71 so you can have yours rebuild to any ratio easy.If you want some billet parts for it look at http://www.eddiemotorsports.com/ for normal parts http://www.ohiomustang.com/ has a lot.
andrewmp6 is offline
Old 01-22-2012, 05:53 AM
Bosko
Bosko's Avatar
Thanks Andrew!
I did discover through this forum and other sources that the 71 - 73 series already had the Shelby drop done at the factory. I guess I should close that thought on my blog,huh? :-)
Thanks for the links on the steering box. My original was gushing fluid, so I replaced it with a rebuilt unit I bought from Pep Boys, of all places. I was wondering if I could change the ratio. I might do so later.
Bosko is offline
Old 01-22-2012, 09:10 AM
andrewmp6
andrewmp6's Avatar
Just talk to http://lee-powersteering.com/ And if you need a wiring diagram http://www.themustangshop.com/resources.cfm and if you want any led lights for it look at http://www.mustangproject.com/
Old 01-29-2012, 09:57 PM
Bosko
Bosko's Avatar
I've added more to my blog. The fabrication of the lower control arms is done, and I have started reassembly of the front suspension.
http://boskomustang.blogspot.com/201...eassembly.html
Bosko is offline
Old 07-04-2012, 09:43 PM
Bosko
Bosko's Avatar
Default Updated blog today
I have pictures and video of the car on a test drive. New brakes, suspension, exhaust, steering, tires, wheels.
Leave comments or thoughts. I have more pictures that I will be uploading over the next few days.
Bosko is offline
1BAD3V
Tennessee Regional Chapter
10-06-2016 12:12 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Sixer4Life
09-29-2015 07:03 PM
1BAD3V
Indiana Regional Section
09-26-2015 09:03 AM
Quick Reply: My 1971 Mach 1
