Help! My Stang is overheating. Changed thermostat. Still over heating.
Could it be a bad thermostat? Water pump doesnt sound cooked? Should I run it without a stat and see if that helps? ( ps. the car is just idling in a driveway. I'm not driving it.
It has been sitting in a driveway for like 10 years. It seems to run okay for like 15 minutes, then warning buzzer starts going off, and then coolant started leaking out through the cap.
Thanks in advance!
Just asking are you sure you put the stat back in the right way?
