Tire Sizing Help!
Old Mar 2, 2006 | 02:32 AM
Shifty101Easy's Avatar
Shifty101Easy
Default Tire Sizing Help!
http://cgi.ebay.com/ebaymotors/ws/eB...3ARTQ%3AUS%3A1
hey, i just ordered those rims for my 1968 coupe and i need to get some tires ordered too, im wondering if 235/45/17 - like they reccomend, is going to be a good choice i tire size?
Old Mar 2, 2006 | 05:18 AM
65_2plus2's Avatar
65_2plus2
Default RE: Tire Sizing Help!
I have Goodyear Eagle ZR45 245/45ZR17s all around on my 65 fastback. So the 235's will work as well. Her is a link to Tech Articles that Fit Late-Model Wheels on a Vintage Mustang
Cheers.....[sm=icon_cheers.gif]
Old Mar 2, 2006 | 05:29 AM
Shifty101Easy
hey thanks. i just ordered the reccomended 235/45/17....the 245 just have a little bit wider rubber right???
i think they will be fine, just want it to look right on the rims....and they reccomended them so whatever, it should be nice regardless.
Old Mar 2, 2006 | 06:40 AM
65_2plus2's Avatar
65_2plus2
Check out this Tire Size Calculator I found some time ago. It works wonders when trying to decide what size tire are a possible fit. Tire Calculator
For instance, plug in the stock tire size (205/70/14) and the new size (235/45/17) and see the difference in width and circumference. Also the speed difference is at the bottom.
Old Mar 2, 2006 | 12:00 PM
pwhit's Avatar
pwhit
62_2plus2,
Do you have any photos of your wheel/tire setup. I'm thinking about a 17" wheel but I'm torn thinking it may look too big. I'm either going 16 or 17 depending on the look. If you have any could you post some photos.
Thanks,
pwhit
Old Mar 2, 2006 | 12:07 PM
slickman's Avatar
slickman
Yup, them are the ones I got for my 66.... I have 225x45-17 on them.
Old Mar 2, 2006 | 06:36 PM
Rorin67's Avatar
Rorin67
One often-overlooked area here is backspacing. Backspacing can be your friend, or your enemy. For example, my 67 came with 235/45s on 17x7 rims in the front - which looked great, but rubbed the fenders ALOT. Everywhere I've seen people put this tire size on the front of 67s so I wondered what was the difference. Turns out the backspacing on my front wheels is only 4", and not the recommended 4.5 - 4.75". With the 4" backspacing, I can only fit 205/50s on front. Lesson learned here - check your backspacing first!
Old Mar 2, 2006 | 08:18 PM
Shifty101Easy
fast shipping for those rims....they said they would be here tomorrow or monday....
Old Mar 2, 2006 | 09:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
[quote]ORIGINAL: 65_2plus2
Good link Chief....I'll add that to the FAQ.
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
M3hunter
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
