Holes in my 302 block
Old Mar 5, 2006 | 11:24 PM
wired2ten's Avatar
wired2ten
Default Holes in my 302 block
So I posted the lifter question last week and got some great advice and info, thanks everyone and it turned out to be 3 bent pushrods. So I said I was going to check the heads and lifters, well I just lept going until everything but the pistons and crank was pulled and found while I thought I had a 289 Hi Po its actually a 302. I want to use this block for the rebuild but there are some holes I'm concerned about. I would post pics but the site isn't letting me. Its a hole 2in in diameter right above where the camshaft sits, so you can see the cam. Theres also a hole the size of a quarter behind where the timing cover plate attachs to the block.
Old Mar 5, 2006 | 11:28 PM
mayh3m's Avatar
mayh3m
Default RE: Holes in my 302 block
i got an extra 302 block w/ castin numbers that say it was made in 79. let me know if you want it.
Old Mar 5, 2006 | 11:32 PM
dodgestang's Avatar
dodgestang
Many blocks have 'holes' in the valley to help speed oil drain back. On the 351c for instance all the blocks look like someone took a hammer and smacked the block with all their might just behind where the dizzy sits.
Old Mar 5, 2006 | 11:36 PM
wired2ten's Avatar
wired2ten
yeah the one by the cam looks like it had a hammer taken to it; edges are all jagged and neither of them definitely do not look professional
Old Mar 5, 2006 | 11:41 PM
351foxstang's Avatar
351foxstang
my 1972 351w block has got a couple of holes about the size of a dime in the lifter valley, like yours.
Old Mar 5, 2006 | 11:46 PM
wired2ten's Avatar
wired2ten
So are these holes ok to have? I'm planning on putting in a lot of high perfromance stuff, like forged crank, pistons, rods and aluminum heads so I don't want to spend a lot of time and money if it the holes might cause damage.
Old Mar 5, 2006 | 11:51 PM
dodgestang's Avatar
dodgestang
Based on description alone and without a pic (to prove otherwise) I would say that you most likely are confusing factory oil drain back releifs for something dire. I did the same thing with my block when I took the intake off the first time:
Old Mar 6, 2006 | 12:05 AM
wired2ten's Avatar
wired2ten
My pic file size is too big for this site. If theres another way to send a pic, let me know
Old Mar 6, 2006 | 12:38 AM
351foxstang
here is a 302 roller block ive got too. does this look like the hole you have?
[IMG]local://upfiles/19521/5ED329389F63491AB096ABDDD13FD277.jpg[/IMG]
and here is my 351w. you can kinda see the holes for oil drainage.
[IMG]local://upfiles/19521/5596DB6B53BA43A3982468FA07CE7EEA.jpg[/IMG]
also i just edit my pictures in paint to make them small enough to fit.
Old Mar 6, 2006 | 02:36 AM
wired2ten's Avatar
wired2ten
I think I posted the pic this time, probably as a link though, that shows the hole I'm talking about that is next to the cam
[IMG]local://upfiles/31112/22F7E853EAA34DB3A43217E86B09459B.jpg[/IMG]
