She wont run.
Old Mar 6, 2006 | 02:56 AM
badazz68stang's Avatar
badazz68stang
Default She wont run.
REturned home from college this weekend to work on my baby, (68 stang w/ 37k orig. miles). AFter several hours of attempts to get her runnin i removed the plugs and found them gas soaked. and bad. Took the torch to the plugs and fired em up and cleaned em off and put them back in. got her to run and began moving stuff out of the way to bring her out but i hadta turn it off cuz of all the fumes n what not. when i was ready to take her out it wouldnt fire back up again. any suggestions? also i am thinkin about runnin a pertronix ingnitioin system and wires any good plug ideas?
Old Mar 6, 2006 | 03:27 PM
wired2ten's Avatar
wired2ten
Default RE: She wont run.
If the pertronix ignition system you're thinking about is the box that replaces the points in your distributor, I wouldn't use it. I tried it on my 65 coupe and the timing wouldn't hold
Old Mar 6, 2006 | 05:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: wired2ten
Many guys, including myself, are running the pertronix module, and I have not had a timing issue with it. Since the electronic ignition doesn't wear, the timing and dwell stays the same.
Old Mar 6, 2006 | 06:10 PM
badazz68stang
so any ideas or suggestions of how to fix the problem of it not starting back up. im pretty sure its something in the fire dept. cuz the plugs were soaked, but if i put new plugs in wont they just become fouled out too?
Old Mar 6, 2006 | 06:16 PM
tylerdru's Avatar
tylerdru
Well the plugs are probably soaked because you flooded the engine when you tried to start it.
Old Mar 6, 2006 | 06:31 PM
badazz68stang
so i need to purchase a new plug set?
Old Mar 6, 2006 | 06:46 PM
tylerdru's Avatar
tylerdru
No, they should be fine. They would need to "dry" off.
Old Mar 6, 2006 | 07:02 PM
Gun Jam's Avatar
Gun Jam
Tyler made a good point but i wouldn’t think that it would flood a second time especially semi warm. You could always check one plug to see if it’s wet. If they are dry check to make sure the choke is working well you could also check spark strength from the coil to a ground and make sure the plug wires are still in good shape.
How did it sound when it ran? How old is the fuel did the exhaust smell funny?
Gun
Old Mar 6, 2006 | 07:22 PM
badazz68stang
after it wouldnt start i actually removed all the plugs and torched the gas off them again, let em cool down and then put em back in. i actually dont have the electric choke hooked up right now and i have jus been drippin a lil gas down the top of the carb. the fuel is fresh but the exhaust did smell a bit funny, maybe just some shlack sittin in the bottom of the tank.
Old Mar 6, 2006 | 07:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Gun Jam
Gun
Good point about the fuel. Old gas turns to varnish after awhile. Even though it may still smell like gas, and even look like good gas, if it is more than 6 months old that could very well be the problem. I had that same problem with mine a few back, and after adjusting the points, timing, etc and it still didn't fire, I decided to drain the gas and start with new gas. That solved my problem. And, with old gas, even if you get it started, it will run like crap. On the highway it will spit and sputter like it has water in the fuel. And, that is another issue. If the car has been sitting for a long time, and the fuel tank was not full, then condensation collects in the tank, causing water to be in the gas. And, we all know that water and gas don't mix.
