289?
Old Mar 7, 2006 | 02:21 PM
MustangSall's Avatar
MustangSall
Default 289?
I've got a '67 and no engine or trans....are the 289s still around, with availible parts?
Old Mar 7, 2006 | 02:33 PM
highhilleer's Avatar
highhilleer
Default RE: 289?
Why do you want a 289? If you are doing a "concours" correct build, then you will need to find a used block with a date code that is 15 - 60 days earlier than the "scheduled" build date of your car. If you are doing a restomod then you would be much better off with a 302 crate engine. There are a wealth of options available for the 302 (or 351W) that would drop into your car. Do a search for 302 crate engines and you'll find complete new with warrenty engines starting at about $3000, very hard to beat! Of course you could pull and rebuild an engine from a junk yard, but watch the costs.
Old Mar 7, 2006 | 03:51 PM
MustangSall
Default RE: 289?
I'm not particular about which engine. I want a small V8 with lots of availible parts....the 302 is propably the best way to go.
Old Mar 7, 2006 | 07:44 PM
mayh3m's Avatar
mayh3m
Default RE: 289?
i got a 302 and c6 tranny combo thinking i'd never find a 289. a few weeks later, i found a 289 so i picked it up. i'm going to use the 289 and c6
Old Mar 7, 2006 | 08:16 PM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: 289?
a 302 will be just a smidge better than a 289.....and your in the 300+ displacement club...so id go with one of those....but thats just me.
Old Mar 7, 2006 | 09:34 PM
BillyBobJoe's Avatar
BillyBobJoe
Default RE: 289?
i like the 351W and hey, it fits. but with a 67, maybe go with an FE block if you've got the money
Old Mar 7, 2006 | 09:38 PM
Shifty101Easy
Default RE: 289?
yeah basically...just go with the biggest engine you can afford...
if your into handling, consider a small block...if you just want to haul buns and dont care so much about the corners a big block is your best bet....
a 351W is a good compromise....i just like the 302 for some reason.
dont forget about the gas devasation....
Old Mar 7, 2006 | 11:31 PM
MustangSall
Default RE: 289?
I'm getting old enough where I don't care as much about power as I do about cost (gas milage). I can get a 302 from a friend of mine....he's got a number of block in his utility shed. They're even pickled. He'll give me a deal.
Old Mar 8, 2006 | 12:28 AM
Shifty101Easy
Default RE: 289?
then do that....u can still get a lot of power out of a 302 if you choose to.
mine burns out a good distance and i have an automatic.
Old Mar 8, 2006 | 01:14 AM
FordMustangXBA's Avatar
FordMustangXBA
Default RE: 289?
Well, my car has the 289 with the 2bbl carb, and the only thing I've added to it so far performance wise is dual exhaust, and I have no problem smoking tires from a stand still with a C4.
