Surface Rust
Old Mar 19, 2006 | 02:48 AM
Moparman87's Avatar
Moparman87
Default Surface Rust
What would the best way about sanding down surface rust on the body of a car?
Old Mar 19, 2006 | 10:20 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Surface Rust
80 grit sand paper and treat it wth phosphoric acid for all the piting and an acid etch primer!
Old Mar 19, 2006 | 12:26 PM
badazz68stang's Avatar
badazz68stang
where can you get phosphoric acid and what exactly does it do?
Old Mar 19, 2006 | 05:56 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
they carry it home depot it kills the rust basically. a brand name is ospho maybe that might ring a bell?i dont know if they carry ospho at the home depot! it treats the metal and gives the proper tooth for the paint
Old Mar 19, 2006 | 06:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
And use a rubber flexible sanding block for the flat surfaces, and your hands for the corners and ridges. Or, if you are going to do the whole car, then consider media/bead blasting. There is also a product called soda blasting. Seems to work great, and there is no risk of warping the metal.
Old Mar 19, 2006 | 11:32 PM
Moparman87's Avatar
Moparman87
what about bad rust? If I put the acid on the rusty holes and stuff with it eat up all the rust?
Old Mar 20, 2006 | 12:49 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
need to grind it out then treat it with the acid! also look in to por15 its a rust encapuslator it work great
Old Mar 20, 2006 | 01:25 AM
Craig67's Avatar
Craig67
Yeah, I was gonna say Por 15.
Old Mar 20, 2006 | 10:06 AM
Soaring's Avatar
Soaring
I ♥ Acer
If the rust has made a hole, then it will have to be fixed. If it is big enough, new metal must be welded in. If it is only a pit, then use a dremel to grind out the rust before using POR 15.
Old Mar 20, 2006 | 01:53 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
u can use por15(silver) and fiberglass mat to fix rust holes the company told me its some strong stuff but well worth the money!
