Locking Lug Nuts
Old Mar 20, 2006 | 11:55 PM
Shifty101Easy's Avatar
Shifty101Easy
Default Locking Lug Nuts
could anyone point me to some new lugs for my new rims on my 68? the cap kind....and with locks....i dont know what ones fit or anything....i dont know the size of the lugs.
any help, thanks.
Old Mar 21, 2006 | 12:05 AM
19stang66's Avatar
19stang66
Default RE: Locking Lug Nuts
check this site out
http://customwheelsmarket.com/wheelinkit.html
I'm sure you can get new ones at a local autoparts store. When i worked at NAPA this past summer i think they sold them.
Old Mar 21, 2006 | 12:07 AM
67t5ponycoupe's Avatar
67t5ponycoupe
They are 1/2 inch. I believe they are 20 threads per inch. Check this link. http://cgi.ebay.com/ebaymotors/Lug-N...49179615QQrdZ1
Old Mar 21, 2006 | 12:08 AM
Shifty101Easy
yeah, i dont really need the valve stems since i already got the tires mounted on the rims...just need a torque wrench to get these nuts off....i might just get some basic chrome lugs from mustangs plus because u can buy them for 95 cents each which is pretty darn good.
Old Mar 21, 2006 | 12:10 AM
Shifty101Easy
oh those are cool, might just get those.
Old Mar 21, 2006 | 01:26 AM
19stang66's Avatar
19stang66
ummm torque wrenches/ratchets are only for tightening nuts, not a good idea to use one to loosen bolts
Old Mar 21, 2006 | 01:31 AM
Shifty101Easy
i meant an impact wrench.
Old Mar 21, 2006 | 02:17 AM
Iskwezm's Avatar
Iskwezm
spend the money on GOOD chromed lug nuts or they will rust/peel in a short while. Once they peel they get to be a pain when you take them off and piece of chrome slices your hand.[:@]
Old Mar 21, 2006 | 09:22 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Iskwezm
Ain't that the truth. Buy the highest quality nuts you can find.
Old Mar 21, 2006 | 10:26 AM
highhilleer's Avatar
highhilleer
ORIGINAL: Shifty101Easy
You should not need an impact wrench, if you do your lug nuts are too tight! I generally use the breaker bar from the 1/2" socket set. Has plenty of leverage. Look at the lug wrench that came with the car. If you cannot remove the lug nut with this, it is too tight!
