Headliner
Old Mar 22, 2006 | 06:44 PM
bdwjdw's Avatar
bdwjdw
Default Headliner
Has anyone ever installed a headliner in an early coupe? If so, was it hard?
Old Mar 22, 2006 | 08:21 PM
Cogtx's Avatar
Cogtx
Default RE: Headliner
Haven't done it but plan to use some vinyl spray on mine when the time comes. I hear it is a real booger to install those headliners...here is a link with some install info for ya...good luck!!!
http://www.virginiaclassicmustang.co...structions.asp
Old Mar 22, 2006 | 09:13 PM
Soaring's Avatar
Soaring
I ♥ Acer
The hardest part is having to remove the windshield and rear window, then replace them after the headliner is in. I didn't have the patience for it, so I had mine done by a pro.
Old Jun 16, 2006 | 04:48 PM
MidNite27's Avatar
MidNite27
I'm doin the install of the headliner right now. Now do you think it is NECESSARY to remove that rear window, or can it be tucked in under the seal and glued in.
Old Jun 16, 2006 | 05:36 PM
slick66stang's Avatar
slick66stang
you can glue it in but its a pain with the windows in
Old Jun 16, 2006 | 05:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
It is my understanding that the 67 and up didn't have to remove the windows. But, I know for a fact that the 65 and 66 have to have them removed if you want a decent looking liner when you are through. Another difficult part is stretchig the corners so they look right.
Old Jun 16, 2006 | 06:02 PM
slick66stang
i put my headliner in myself not the greatest idea i have had. with someone else you can put it in but its not going to be looking showroom quailty.
Old Jun 16, 2006 | 06:15 PM
67Rally's Avatar
67Rally
I was just pulling all of my past M&Fs to find the various headliner install instructions. It sure doesn't look like fun. The way I do things, I might have to buy a couple of them.
Old Jun 16, 2006 | 08:36 PM
351foxstang's Avatar
351foxstang
does a new headliner kit come with the metal rods that hold it against the roof of the car?
Old Jun 16, 2006 | 08:41 PM
Soaring's Avatar
Soaring
I ♥ Acer
I just bought the headliner and had a pro install it. Mine didn't come with the metal rods. I don't see why you would need to order those anyway. Meaning, the ones you already have are probably good to go.
