Transmission identification
Old Mar 25, 2006 | 06:00 PM
Clu7ch's Avatar
Clu7ch
Default Transmission identification
I need to know what kind of transmission is in my stang. is there a marking on the trans that'll indicate what type it is? Now, i know what you're thinkin, "the vin will give you the answer". the only problem there is, the vin says 3-speed man trans and the car has a 3 speed auto. the trans and the color (which has been confirmed by startin the body work) are the only things that were changed. any help in identifing my trans will be greatly appreciated. Thank you.
Old Mar 25, 2006 | 06:06 PM
Twister's Avatar
Twister
Default RE: Transmission identification
ORIGINAL: Crash
the VIN has no tranny code, TRUST ME...as for the 3 speed auto, it depends on the year and engine. If it is aluminum, it is either a C4 or a C6, a C4 has a seperate bellhousing, while a C6 has an entegral one, and if it is cast iron, then you have an FMX
Old Mar 25, 2006 | 07:10 PM
Clu7ch's Avatar
Clu7ch
I'm sorry, i didn't mean the vin. i ment the tag on the door. i forget what it's called, but it states production codes, color, trans, engine, int, ect.
the stang is a 66 with a 200ci inline 6. it's still cold out here, so when it warms up i'll crawl under her and see what i can see. thanks twister.
Old Mar 25, 2006 | 09:27 PM
mayh3m's Avatar
mayh3m
try here ford transmissions. it has great pictures
Old Mar 25, 2006 | 11:31 PM
Clu7ch's Avatar
Clu7ch
Thanx mayh3m. that ought to do it. pics will def help a lot.
Old Mar 25, 2006 | 11:39 PM
Baker's Avatar
Baker
Here Ya Go!!
Old Mar 26, 2006 | 01:24 AM
Twister's Avatar
Twister
ORIGINAL: Crash
you have a C4
The FMX was for the 351's and the big blocks got the C6
Old Mar 26, 2006 | 04:04 PM
Clu7ch's Avatar
Clu7ch
Thats what i had figured. my next question is, what do i need to get to hook a 5.0 stroked to 347 to that trans? i know i'd need to change the bellhousing and torque converter, anything else i need to change?
Old Mar 27, 2006 | 03:01 PM
Twister's Avatar
Twister
ORIGINAL: Crash
try changing everything but the case, there are less clutch packs than a V8 tranny, as for a V8 swap, the tranny is the least of your concerns, the rear end and front steering componants are barely adiquite for your I6....
Old Mar 27, 2006 | 07:21 PM
Clu7ch's Avatar
Clu7ch
ORIGINAL: Twister
True enough, and already being taken care of. got an 8.8 dif out of a 93 Mark VIII, hoping to be able to use the axle's with that for now. also, coilover front ($2200) and rear ($3500-$5500) suspension www.totalcontrolproducts.com . as for the steering, i'm going with, i think it's flaming river's, rack and pinion steering conversion.
back to the trans, should i just go ahead and convert it to a t5 while i'm doing everything else?
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
