Crankshaft Dampener
Old Mar 30, 2006 | 01:20 AM
mustangteen87's Avatar
mustangteen87
Default Crankshaft Dampener
Disassembling my 289 and the book tells me to remove the crankshaft dampener. Well I got the front nut off, but even with all and bolts to the timing chain cover removed, oil pan removed, and using a harmonic balancer, I just can't seem to get the darn thing off. Someone plz give me some hints on if there is anything else I need to remove, unbolt, or detach. If not then tell me how to get the darn thing off.
Thanks SOO MUCH!!
Old Mar 30, 2006 | 01:24 AM
Craig67's Avatar
Craig67
Default RE: Crankshaft Dampener
Isn't that the part that you screw a steering-wheel puller on to and pull it off in one piece? Smarter guys will correct me if I'm wrong.
rmodel65's Avatar
rmodel65
Yukon Cornelius
go to auto zone an ask for the loan a tool harmonic balancer puller just leave a deposit and gety ur money back when u return it
Old Mar 30, 2006 | 10:31 AM
earlymustang's Avatar
earlymustang
ORIGINAL: rmodel65
I did this as well w/a rental puller from Advance. The only way to correctly remove it and install. Have it rebuilt/replaced if needed while it is off (damperdoctor.com)
Old Mar 30, 2006 | 02:22 PM
6mustang6's Avatar
6mustang6
yeah, what they are trying to say is, you need to rent a puller to remove the balancer. I know they suck.
Old Mar 30, 2006 | 04:30 PM
mustangteen87
thanks i'll try it out
bryan616fl
Jan 25, 2019 09:07 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
S'PortMustang69
Aug 30, 2015 08:27 PM
uedlose
Aug 21, 2005 05:58 PM
