Rust help
Old Mar 30, 2006 | 03:14 AM
mustangfan87's Avatar
mustangfan87
Default Rust help
So i got a pair of tri y headers the other day from my friend and they are completly rusted out. Like someone paint them with it. My question is what is the best way to get them clean. I have already started on one with my sander but thats taking a very long time. Any info would help.
Old Mar 30, 2006 | 04:11 AM
Shifty101Easy's Avatar
Shifty101Easy
Default RE: Rust help
some sort of media blasting....or dipping in acid stuff....but those are both very costly if you dont already have the stuff........if they are rusted inside i dono how your going to get the crud out without a huge pipe cleaner and a lot of hard labor.......
Old Mar 30, 2006 | 04:50 PM
88BlueGT's Avatar
88BlueGT
You can use a wire brush on the end of a drill. Depending on how bad they are rusted that should take it off pretty quick. Than make sure to apply some high temperature paint...
Old Mar 30, 2006 | 04:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: mustangfan87
whoa...back up there. where are you sanding?? Do not just sand the gasket surfaces, you could cause pitting or miniscule leaks from uneven sanding like that. It's okay to sand everything but the gasket surfaces. That's just asking for more work.
Old Mar 30, 2006 | 05:32 PM
highhilleer's Avatar
highhilleer
The 3M rust stripper pads work well. I assume you mean they are coated with rust, not rusted through. How are you going to protect them form rusting again?
Old Mar 30, 2006 | 11:36 PM
Baker's Avatar
Baker
Sandblast Baby!!!!
Old Mar 30, 2006 | 11:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
Buy some new headers.
Old Mar 30, 2006 | 11:48 PM
Shifty101Easy
yeahh, i mean if you dont have access to any of this stuff....you could like hand sand i guess.....but that dosent make sure the insides are clean.......or u could bring it to get sandblasted....which theres a good chance it will be more for that than to just buy some new tri-y's....
try posting them in craigslist and see what you can get people to bite for.....if its good then it would just displace the cost of new ones....
GPR
Dec 16, 2015 12:21 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 17, 2015 07:57 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
