Suspension question.
Oh, well that's not really size is it? I don't know the difference, other than more leaves. I don't know what it actually does though, so I'll let someone else respond...
Wouldn't more leaves raise the ride height though? If he wants to drop it, shouldn't he go with 4-leaf mid-eye?
How many leafs determines stiffness. I have 5 leaf reverse eye. With 5 leafs and a fat sway bar it is super stiff. My car has no body roll around corners and has a ride like a racer. If you are going for a performance build you would probably want 4.5 or 5 leaf. The largest sway bars and the heaviest # coil springs will get you a really solid cornering car. Do the Shelby drop with it and yours will be pretty much a performance ride.
4 leaf is what came on your car originally. 4 1/2 leaves will give you a slightly stiffer ride, and a 5 leaf spring should only be used with a beefed up rear end using beefed up torsion bars, etc. And, if you do use 5 leaves, get ready for a bumpy ride. I replaced mine with 4 leaves, and it raised my car back up to factory specs because the old 4 leaves were sagging with age. If you are basically stock, and don't plan to put in some serious power to the rear, just stay with the 4 leaves. No more than 4 1/2.
Wow, are you sure on the Watts? My understanding is that you only need that for serious corner carving "Open Track Racing." It is a pretty expensive mod for a standard street driver car. IMHO you would be better off with standard style sway bar, performance leafs, and nice shocks. But, I do not corner carve, nor do I know your application.
