Cleaning the exhaust?
Old Mar 31, 2006 | 04:43 PM
Rorin67's Avatar
Rorin67
Default Cleaning the exhaust?
That darn heavily-leaking power steering system (that I just replaced with a manual r&p system) used to splash tons of fluid onto my headers and exhaust. Now the fluid is caked on and has a less-than-desirable odor once the exhaust heats up. So, how does one clean ceramic-coated headers and stainless steel exhaust? I'd like to take some simple-green and a wire brush, but will that hurt it?
Old Apr 1, 2006 | 01:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Cleaning the exhaust?
Simple green and a wire brush may do the trick. You might want to use some kind of acid to break it loose. Muriatic comes to mind. But, only leave it on for a few seconds. Or, you might want to research into aircraft exhaust cleaners. I can't vouch for it, but it sounds like it will work. http://www.aeroperform.com/aircraftp...-XD1532-GL.asp
Old Apr 1, 2006 | 01:55 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
theres a really good chance that will work, anything that was made to clean an aircraft works great on a mustang. the most popular stuff we use to clean rust and grime is ACF-50, but it is kinda pricey, but if you find some i would buy a bottle, that might do the trick too.
after we spray it on we use a toothbrush to get to those small places.
Old Apr 1, 2006 | 03:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
The Simple green and wire brush might help, but I think I would use either a bit of Muriatic acid or check into the link above for aircraft exhaust cleaner.
EZFEED
May 5, 2016 08:54 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Sep 10, 2015 08:39 PM
kevsgt
Sep 9, 2015 06:20 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
