gauge cluster
Old Apr 9, 2006 | 10:22 PM
  #21
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: gauge cluster
Oil pressure sending unit is differnet. Not sure about the amp gauge but it must be different. The easy way would be to get the wiring out of a 66.
Old Apr 9, 2006 | 10:32 PM
  #22
serge627's Avatar
serge627
Is there a write up on what needs to get changed? I have a 66 cluster in my 64 1/2 and the fuel, and speedo are the only things that work. I bypassed the sensors (went right to ground) and the other gauges are working, they just dont read whatever signal they should be getting from the temp. and oil pres. sensors???
Old Apr 9, 2006 | 10:33 PM
  #23
ngirg001's Avatar
ngirg001
i have those gauges in my 65 but in black. They came with the car and i replaced them with some rep ones. The ones i took off were OEM Ford parts yet my car never came with pony interior. maybe the PO put them on?? The speed gauge works and so does the oil but the others dont.
Old Apr 10, 2006 | 12:21 AM
  #24
Cogtx's Avatar
Cogtx
Adrian...I have a 67 coupe and replaced the instrument voltage regulator with solid state. However, Does the 65-66 have an instrument voltage regulator on the back like the 67's. If so, the one in the pic might be missing it. Or I just have old eyes which can't seem to find it...
Old Apr 10, 2006 | 12:35 AM
  #25
serge627's Avatar
serge627
You are right it should have a voltage regulator on it, and it does not. You can actually see that the metal is a lighter grey in the area where it is supposed to be just to the right of the large speedo circle.
Old Apr 10, 2006 | 03:47 AM
  #26
6fivestang's Avatar
6fivestang
i have the standard cluster in my 65 right now but i really perfer to have this style? so if you were in my shoes would you guys pass it or go for it?
Old Apr 10, 2006 | 03:50 AM
  #27
6fivestang's Avatar
6fivestang
well actually...its more like if you guys were in adrian shoes would you guys go for it or just wait?
Old Apr 10, 2006 | 08:16 AM
  #28
slickman's Avatar
slickman
I would just buy mine
ORIGINAL: 6fivestang
Old Apr 10, 2006 | 12:44 PM
  #29
ADRIAN1's Avatar
ADRIAN1
so is the voltage regulater fixable?does it cost alot?and, should i buy it? i need to know buy tommorrow. please help!!!
Old Apr 10, 2006 | 01:08 PM
  #30
serge627's Avatar
serge627
The new regulator is 37.95 from Mustangs Plus, and its easy to replace.
