cleaning the coolant system
Old Apr 9, 2006 | 08:32 PM
BillyBobJoe's Avatar
BillyBobJoe
Default cleaning the coolant system
unfortunatly, when i drained my anti-freeze, i noticed an uncomfortable amount of brown water. plus the visible rust all over the inside of the block where the coolant travels and etc. what if I use some type of heavy duty rust remover and fill up the engine's water passages or whatever they're called. i assume it would help but if i dont drain it all, could it cause a problem in the future? any opinions?
Old Apr 9, 2006 | 09:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: cleaning the coolant system
Billy, don't use any engine or radiator flush acid. You will just chunk off more rust and it will collect in your radiator. Just do an engine/radiator flush with clear water. Get an in-line radiator hose flush "T" and hook it up to the garden hose. Plug it in, and then run the engine with the rad cap off. Here is a pic of where that "T" goes. After you start to see clear water, shut it off and drain all the remaining water through the **** at the bottom of the radiator. Close that and fill it with a mixture of anti-freeze and water. You might need tp use a 30/70 mixture. http://pic10.picturetrail.com/VOL326.../138402220.jpg
Old Apr 9, 2006 | 10:17 PM
BillyBobJoe
i have my engine completely dissambled though. lol. i forgot to mention that
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 24, 2015 09:18 PM
