Starter Problem???
okay as some of u know....i screwed up my wiring a few days ago with the fan blade cutting it all...but every wire was put back together, completely fixed, and everything works so im pretty much assuming thats not the problem here.....all lights, signals, horn....everything electrical works.....but sometimes the engine wont crank at all......
is this a bad starter??? how can i tell??? i drive my car everyday for 15-20 minutes just to keep everything from sitting and getting stale and crappy and what not.....so i go out there today and go to start it....it kinda cranks then stops....then wont crank for like 20 minutes.....i gave up....walked inside, got a coke, came back out, first tirn of the key the thing fires up, roaring like a bear.....
it ran great for at least an hour of driving today....turn it off, turned it back on, starts up great.....
it just does that no start thing sometimes and i dont know why....does anyone know what the problem could be???
Do not whack the starter. If cut wires going to the soleniod then that is the problem. The pic you posted yesterday had the small red wire going to the soleniod broken. It had a blue lug where it goes on the soleniod. Did you fix that? That is the wire that tells the starter to crank. Smack the starter! I freaking swear!
if you give the solenoid a nice hard tap on the top, while supporting it with the other hand that could help you out....happens to me once in a while. also, is it hot when your having these problems? sometimes a hot starter doesnt like to roll over.
no, completely cold...hadnt been run for more than 24 hours....
and all those wires were replaced....its all fixed and makes good connection so im almost sure its not that........when it dosent turn over i can hear it make a "click" sound or whatever......
the thing about it is that even before the wires were cut it would do that.....so its hard to pin point that as the culprit.....i guess if i can find out the right wiring harness for all those wires i can jsut redo all the wires again.
its a pretty new battery and the cables are 100% clean....everything works except the starting sometimes like lights and horn and all that so its not the battery or cables from it......
