SHORT BLOCK
Old Apr 12, 2006 | 06:50 PM
tylerdru's Avatar
tylerdru
Default SHORT BLOCK
My shortblock is here!!!! My question is, How do i get it off of the pallet. It is sitting with the crankshaft upwards. Would you recomend a cherry picker? If so, Where would i connect it with the engine upside down.
[IMG]local://upfiles/20996/FACE654614E94504ABAFC350B5BE138F.jpg[/IMG]
Old Apr 12, 2006 | 06:55 PM
Craig67's Avatar
Craig67
Default RE: SHORT BLOCK
Get someone to help you turn it over and lift it how you're supposed to. Don't want anything happenning to your new short block.
Old Apr 12, 2006 | 06:59 PM
tylerdru's Avatar
tylerdru
My dad and i will be able to lift it. I suppose.
Old Apr 12, 2006 | 10:41 PM
Scott H.'s Avatar
Scott H.
IIRC, it will be about 250 lbs. Lay it gently down on the plastic it was wrapped in while still on the pallet with the lifter valley up. Use a couple of extra bolts threaded all the way down in the head bolt holes at oposite corners of the block, closest to the lifter valley . If you've got any flat stock laying around, make two lifting eyes. And yes, save your poor old dad's back and use a chain hoist. It will be much easier for him to reach his wallet, if his back doesn't hurt
Congratulations! That will be a fun project.
Old Apr 12, 2006 | 11:00 PM
tylerdru's Avatar
tylerdru
My dad is not old enough. He just turned 40 ill have him holding the block. Really. We have a 400 pound tv that we have moved before. My tv is 250 pounds. I will probably end up renting a cherry picker if i can.
Old Apr 12, 2006 | 11:25 PM
acidrain088's Avatar
acidrain088
a shortblock suprisingly isnt too heavy. bolt the plate of your engine stand to it so that all you have to do is is slip the tube into the stand base. just get a friend and your dan and you be just fine
Old Apr 12, 2006 | 11:29 PM
tylerdru's Avatar
tylerdru
acid rain, thanks for the plate info. THAT WILL HELP ALOT
Old Apr 12, 2006 | 11:30 PM
6mustang6's Avatar
6mustang6
i can bet you they are pretty heavy. I would just buy a hoist. You will need it sooner ort later. And you can always use them.
Old Apr 13, 2006 | 08:14 AM
tylerdru's Avatar
tylerdru
What size bolts do i need to hold the engine to the stand? Can i buy some at a hardware store?
Old Apr 13, 2006 | 09:41 AM
Cusbuild's Avatar
Cusbuild
hey tyler what are you doing with the old block from your sig?
