engine wont start
Old Apr 13, 2006 | 09:42 PM
jts302's Avatar
jts302
Default engine wont start
so i got my heads back from getting a valve job done on them i put the heads intake distributor and carb back and it wont start i have no clue what the prob is
Old Apr 13, 2006 | 10:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: engine wont start
ORIGINAL: jts302
Check to make sure your coil wires are connected right, and that you have either the points or electronic ignition module set (gapped) properly. Pour about a tablespoon of gas in the carb, and pump it about 3 or 4 times. Look into the venturi to make sure there is gas being pumped into the carb.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Spiral534
Oct 6, 2015 04:31 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
