Radiator size question
Old Apr 14, 2006 | 12:22 AM
ideal_mustangs's Avatar
ideal_mustangs
Default Radiator size question
Okay, so here's my question. I bought a new radiator for my car today becuase I busted my old one. It was an original ford radiator, but had been changed back in the early 70's when my uncle wrecked it. It is smaller in width that the replacement that I got from the auto parts. The replacement will work, but my question is, was the ford one that was in the car out of a 6cyl and the replacment for a v-8, or whats the difference? My car is a 289.
Old Apr 14, 2006 | 03:40 AM
Kriger's Avatar
Kriger
Default RE: Radiator size question
dual and triple cores I believe, I put a triple core in my 66.. a little deeper but does alot better job cooling over the previous dual core "thinner" one i had before...
Old Apr 14, 2006 | 11:11 AM
Soaring's Avatar
Soaring
I ♥ Acer
The original rads were 2 core for both the I6 and the 289. I replaced mine with a 4 core and it slipped right in. I have 1 1/2 inches between the rad and the fan, and the new shroud fits perfectly. My spacer on the fan is about 2 inches long, so if I had not been lucky, I could have changed the spacer to a shorter one.
Old Apr 14, 2006 | 03:27 PM
ideal_mustangs
It's not thicker, as in the number of cores, it is wider as in the actual dimensions of the radiator. Lets see If I can describe what I'm saying. the top part, with the radiator cap on it, is longer than the one that was in the car.
Old Apr 14, 2006 | 04:15 PM
Soaring's Avatar
Soaring
I ♥ Acer
Still slides right in though.
Old Apr 14, 2006 | 07:00 PM
ideal_mustangs
Yeah, it works and the wider the better because of cooling power, but I was just curious.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
DrunknRuckus
Aug 23, 2015 10:05 AM
mustangsrforever!!!
Aug 6, 2015 12:04 PM
