1966 fastback Frame rails
Old Apr 14, 2006 | 08:18 PM
want_66fastback's Avatar
want_66fastback
Default 1966 fastback Frame rails
I am looking at a car that a guy restored that he said he has done EVERYTHING on it . It has NEW fram RAILS put in as well. I does NOT come with the Quarter panels put in, No tubs, No trunk floors. They need to be welded in and finshed out.
Here is my big Concern, is that he might have been off one way or another when he put these fram rails in. This would make it have problems putting these parts back together.
Let me ask HOw could I measure to MAKE SURE these Rails were INDEED put in RIGHT!!
Is there som data some place that has all the demisions?
Old Apr 15, 2006 | 08:42 PM
want_66fastback
Default RE: 1966 fastback Frame rails
bump
Old Apr 15, 2006 | 09:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
I'd pass. That sounds like a real nightmare.
Old Apr 16, 2006 | 02:13 AM
lonos_new_curse's Avatar
lonos_new_curse
Yeah, even though it is a fastback, I would second what Soaring said. Sounds like one hell of a rustbucket if he had to replace everything. Unless you are a maestro with a welder, and a glutton for punishment, I'd keep looking.
Old Apr 16, 2006 | 02:31 AM
slickman's Avatar
slickman
I second that..
ORIGINAL: Soaring
Old Apr 16, 2006 | 02:50 AM
want_66fastback
Well EVERTHING is done except for that....It is REALLY clean!! I needs the Quarters welded on, the Wheel housings put in, and the trunk flors put in....
Old Apr 16, 2006 | 11:10 AM
slickman's Avatar
slickman
Well, it sounds like it was in bad shape at one point but, it also sounds like the guy was doing the job right. In my view, it depends on how much you're getting this fastback for. You can pick up a nice project fastback for around $8,000 - $10,000 that does not need allot of work like that. Plus, if you look around for some time, you will find great deals out there. Take a look at this one.
Fastback
ORIGINAL: want_66fastback
poke68
Dec 16, 2025 03:36 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
mrappe
Sep 26, 2015 10:16 AM
Sep 24, 2015 09:18 PM
Sep 17, 2015 07:57 PM
