Trunk Pressure Valve
Old Apr 14, 2006 | 10:52 PM
68Midnight's Avatar
68Midnight
Default Trunk Pressure Valve
So i was cleaning the trunk out when I noticed a little air pressure valve that sticks out. Whats it for? I was thinking possibly air shocks? Becuase I noticed in the front I have two holes in my shock towers that leed to little brake bleeder look-a-like valves....i was assuming air shocks as well...any information is good information. Thanks!
Nathen
Old Apr 14, 2006 | 11:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Trunk Pressure Valve
Yeah, those are for airing up air shocks. Get rid of that crap.
Old Apr 14, 2006 | 11:10 PM
68Midnight's Avatar
68Midnight
Suggested upgrade?
Old Apr 14, 2006 | 11:13 PM
slickman's Avatar
slickman
Air shocks are normally crap but, if they are good ones, they may not be bad if used right. I have them in my 66 but, they are a good set. They came with the car when I got it, however, you're better off with new springs. I'm in the process of getting a new set of rear springs that give it a 1 1/2 inch lift over stock (stock was always too low). So, use them until you can swing a new set of springs.
Old Apr 14, 2006 | 11:14 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 68Midnight
Suggested upgrade?
KYB gas adjust. http://www.kybshocksonline.com/default.aspx?KID=333
Old Apr 14, 2006 | 11:18 PM
slickman's Avatar
slickman
Those are good, I have a set waiting to go in my 66 but, I need to replace the springs first or it will sit too low.
ORIGINAL: Soaring
Suggested upgrade?
KYB gas ajust.
Old Apr 14, 2006 | 11:21 PM
67t5ponycoupe's Avatar
67t5ponycoupe
The ones in the front are grease fittings also called zerks.
Old Apr 15, 2006 | 12:07 AM
dcohen's Avatar
dcohen
what is it with people putting air shocks on mustangs? ive bought three mustangs so far and out of the three two of them have had air shocks on them. the 72 mach one i bough had them as did one of the 66 coupes i bought[:'(]
Old Apr 15, 2006 | 12:14 AM
slickman's Avatar
slickman
Its a cheep and easy way of getting the rear end back up were it should be..
ORIGINAL: dcohen
Old Apr 15, 2006 | 12:17 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: dcohen
That was the thing back in the day. If you wanted to jack up a car in the rear, you just added air shocks, and walllllah, you had a jacked up rear. Same thing with extension shackles. Performance from the rear was crap though, so they were replaced with more modern parts to achieve the same without suffering from performance from the rear.
