Stock Speaker Location?
Old Apr 18, 2006 | 10:41 PM
badazz68stang's Avatar
badazz68stang
Default Stock Speaker Location?
Can someone tell me where the stock speaker locations are on a 68 coupe?
Old Apr 18, 2006 | 10:47 PM
Yoruai's Avatar
Yoruai
Default RE: Stock Speaker Location?
If its the same as a 67 you got two on the back dash behid the seat, one behind each front kicker panels and one under the front dash in the middle. There are aftermarket kicker panels that let the speaker show through.
Old Apr 18, 2006 | 11:25 PM
6mustang6's Avatar
6mustang6
NOOOO. STOCK, they only had the speaker under the dash. NOW, they had options which put some behind the rear seat.
Old Apr 19, 2006 | 01:46 AM
Philostang's Avatar
Philostang
ORIGINAL: 6mustang6
+1
Stock cars had no provisions for speakers in the kickpanels. Aside from the aftermarket kits to put two 8" subs behind the rear seats, they also make aftermarket kickpanels that allow you to run 5.25" rounds (but these are new units).
BTW, if you're interested in doing the sub thing in the back, one manufacturer incorrectly says that 8" subs are the largest you can run. This is not true. I put two 10" subs behind my 68 coupe. The trick is to pick a sub that has a shallow enough basket to allow you to place it low in the space between the hump in the trunk and the panel the subs will mount on.
Best,
-j
unit91
Sep 15, 2015 09:53 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Gabe_mlcc
Sep 7, 2015 11:56 PM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
